2003 toyota camry remote start
seanw
Member - Posts: 7
Posted: January 04, 2004 at 3:47 PM / IP Logged
i'm trying to install a stand alone remote start and i cant seem to find the factory disarm wire. if anyone can help i would deeply appreiciate the information.
Bnluis
Silver - Posts: 578
Posted: January 04, 2004 at 3:54 PM / IP Logged
FACTORY DISARM
BLUE (-)USE KEYSENSE WIRE
*1 - Using the status output wire from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
seanw
Member - Posts: 7
Posted: January 04, 2004 at 4:33 PM / IP Logged
thank you for the wire information, luis, you've been a big help!!
draasch
Gold - Posts: 2,172
Posted: January 04, 2004 at 6:09 PM / IP Logged
Make:   Toyota
Model: Camry
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 885
Alarm
Constant 12 volts WHITE/ RED OR WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK / YELLOW AND BLACK /WHITE AT IGNITION SWITCH HARNESS *
Dome Light GREEN/ RED (-) IGNITION KEY CYLINDER LIGHT
Trunk Pin Switch GREEN / WHITE (-) AT THEFT DETERRENT E.C.U. **
Parking Lamp GREEN (+) AT THE BACK SIDE OF E.C.M.***
Power Lock BLUE / YELLOW 13 PIN GRAY CONN. IN DR KICK
Power Unlock BLUE 20 PIN WHITE CONN.IN DR KICK ****
* There Are Two BLACK / YELLOW Wires Please Check. ** Theft Deterrent E.C.U. Is Located Behind Pass Side Dash Top Right. *** E.C.M. Located Above Drivers Kick Panel A Part Of Fuse Box. **** First Pulse Unlocks Driver 2nd Pulse Unlocks The Rest. #201 - See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
draasch
Gold - Posts: 2,172
Posted: January 07, 2004 at 9:00 AM / IP Logged
Make:   Toyota
Model: Camry
Year:    2002
Index #: 5825
Alarm
* There Are Two BLACK / YELLOW Wires Please Check. ** Theft Deterrent E.C.U. Is Located Behind Pass Side Dash Top Right. *** E.C.M. Located Above Drivers Kick Panel A Part Of Fuse Box. **** First Pulse Unlocks Driver 2nd Pulse Unlocks The Rest. #201 - See Negative Pulse Door Lock Diagram. OEM Alarm Hood Trigger:BLACK At Antitheft Module Behind The Glove Box.
Remote Start
Tach Signal WHITE AT DATA LINK CONNECTOR
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS *
Ignition #3 #239
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NON GROUNDING TYPE
Brake Light GREEN / WHITE AT SWITCH ABOVE BRAKE
Reverse Light WHITE/ RED DRIVERS DOOR SEAL HARNESS
Rear Window Defrost
#239- See Immobilizer Bypass Diagram (Some Vehicles Reported W/O) Omega Part:DB-PKT All Toyota/Lexis 98-02 (No Key Required). * Cold Start Wire BLACK / YELLOW There Are Two BLACK / YELLOW Wires One Tests Like A Starter Wire The Other Like A Ignition ,Please Check.
Good Luck
David
Ace Security
813-376-9778
Tampa
