Remote Starter for 2000 Nissan Altima
meh66
Copper - Posts: 266
Posted: January 09, 2004 at 12:17 PM / IP Logged
I need some help figuring how to install this remote start. I have many years experience installing car stereos, but I only installed one alarm with a remote start. I just want to be prepared before I take on this job. I know the car has a resistor in the key. Do I need a bypass module or will the alarm disable from the remote starter handle that function. I have read the two Altima installs for 1999 and 2002, but I was not sure if this has the same issues. Any help would be much appreciated.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
draasch
Gold - Posts: 2,172
Posted: January 09, 2004 at 2:39 PM / IP Logged
Make:   Nissan
Model: Altima
Year:    2000
This Database Was Last Updated On:    6/9/2003
Index #: 8231
Alarm
Constant 12 volts WHITE/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) WHITE 6 PIN CONN.IN DR.KICK PANEL***
Trunk Pin Switch RED (-) AT LIGHT IN TRUNK *
Parking Lamp RED / BLUE (+) AT HEADLAMP SWITCH **
Power Lock GRAY AT "SMART ENTRANCE #201
Power Unlock PURPLE CONTROL UNIT" ***
* RED (-) Trunk Pin Wire Is Also Located At "Smart Entrance Control Timer". ** RED / BLUE (+) Park Light Wire Is Also Located At Fuse Block In Driver Kick Panel. *** "Smart Entrance Control Unit" Is A BLUE Module Which Is Located Behind The Driver Dash To The Right Of The Steering Column.See Tech Note Alt.Door Tri #201- See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal L GREEN/ ORANGE (-) WHT 18 PIN CONN. NEXT TO PASS KICK
Ignition #2 BLACK/ PINK IGNITION SWITCH HARNESS #239
Ignition #3 N/A
Accessory WHITE/ BLUE IGNITION SWITCH HARNESS
Neutral Safety GREEN/ ORANGE (-) AT INHIBITOR SWITCH
Brake Light RED / GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light GREEN (+) AT INHIBITOR SWITCH
Rear Window Defrost GREEN/ BLACK (-) AT REAR WINDOW DEFOGGER SWITCH
#239 See Immobilizer Bypass Diagram. Cold Start Wire - BLACK/ BLUE.
they may have a by-pass kit out for that car...im not sure. here is another way to by-pass it:
http://wiringinstructions.com/239.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
