2003 chrysler town and country starter
bmf1000d
Silver - Posts: 345
Posted: January 09, 2004 at 2:25 PM / IP Logged
im haveing trouble with the engine starting. It cranks over but it does not start. I have the relay wired for the 180 ohm negative for the 2 starter wire. I was wondering if that could be possibly a ingintion wire and not a start wire. Any information you have would be helpful...
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
draasch
Gold - Posts: 2,172
Posted: January 09, 2004 at 2:35 PM / IP Logged
Make:   Chrysler
Model: Town & Country (Van)
Year:    2002-03
This Database Was Last Updated On:    6/9/2003
Index #: 5820
Alarm
Constant 12 volts L BLUE IGNITION SWITCH HARNESS *
Ignition 12 volts PINK/WHITE IGNITION SWITCH HARNESS **
Starter YELLOW (+) IGNITION SWITCH HARNESS
Dome Light YELLOW/WHT (+) PIN 33 OF 34 PIN CONN. AT B.C.M.
Trunk Pin Switch VIOLET/ORANGE (-) PIN 29 OF 34 PIN CONN.AT THE B.C.M.
Parking Lamp WHT/BRN(RESISTOR SYS.) AT HEADLIGHT SWITCH (SEE TECH NOTES)
Power Lock VIOLET/D GREEN AT B.C.M.LOWER LEFT OF STEERING ***
Power Unlock SINGLE WIRE SYSTEM COLUMN IN PIN 21 WHT 34 PIN CONN.#217
* All Wires Are 20 Gage.L BLUE Fused At 10 Amps. For main Power Connection Connect To BROWN / RED Or WHITE/ RED Fused At 20 Amps At 6Pin Conn. At B.C.M. ** Ignition Wire Controls All Accessories. *** Chassis Ground Thru A 5.3k To Lock And Chassis Ground Thru A 2k Ohm Resistor To Unlock. ( Connector Is Third Up From Bottom Of BCM) #217-See Single Wire Resistor Door Lock Diagram
Remote Start
Tach Signal D BLUE/D GREEN PIN 11 GRAY/BLACK 40 WAY CONN.P.C.M.*
Ignition #2 See Note Below **
Ignition #3
Accessory
Neutral Safety WHITE/ LT GREEN PIN 9 OF 34 PIN CONNECTOR AT BCM
Brake Light WHITE/ TAN (+) AT SWITCH
Reverse Light WHITE/ LT GREEN (+) PIN 9 OF 34 PIN CONNECTOR AT BCM
Rear Window Defrost
* Power Control Module Located Left Front Corner Of Engine Compartment. Ignition Input To Keyless:PINK/WHITE ** VIOLET/BROWN and VIOLET/ORANGE Must See 180 OHM Resistor Between Them During Start Due To Multiplexing. #239 - See Immobilizer Bypass Diagram.
if you are using an omega product...here is the number for them:
1-800-554-4053
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
bmf1000d
Silver - Posts: 345
Posted: January 09, 2004 at 2:56 PM / IP Logged
Still dont start. it will start with the key but not the RS. I dont have a violet/orange wire all i have is the viol/brn and thats it...
"Big" Mike
Double Take
Fremont, Ne
draasch
Gold - Posts: 2,172
Posted: January 10, 2004 at 1:47 PM / IP Logged
how did you make out on the remote start?????
Good Luck
David
Ace Security
813-376-9778
Tampa
bmf1000d
Silver - Posts: 345
Posted: January 10, 2004 at 11:56 PM / IP Logged
Still did not work so im gonna tackle it on monday with a fresh start
"Big" Mike
Double Take
Fremont, Ne
denis mcginn
Member - Posts: 6
Posted: January 11, 2004 at 9:58 AM / IP Logged
I think you need to create both crank and run resistance circuits at the ignition switch sense wires to the bcm. this is what I had to do on 02 caravan, but unfortunately I dont remember the resistance values. You can measure at switch to get proper values of the crank and run. poss two violet wires. I think the values are 180 ohm and 300????
