1995 isuzu pickup viper 971xv
fireman1321
Member - Posts: 20
Posted: January 10, 2004 at 1:38 PM / IP Logged
I have a 1995 isuzu pickup, I need to know how to install the viper 971xv into it... I need to know what the orange and blue wires on H1 go to and I need to know how to install the primary remote start harness also, Please help! I also need to know what the headlight wire in the vehicle is also. Thanx!
Future Fire Man
draasch
Gold - Posts: 2,172
Posted: January 10, 2004 at 1:42 PM / IP Logged
post a link for that unit.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
fireman1321
Member - Posts: 20
Posted: January 10, 2004 at 2:05 PM / IP Logged
I need to know what the blue/white wire does on the H1 harness. and I also need to know what the orange wire on the primary remote start harness goes to plus the orange wire on the H1 harness. PLEASE HELP!
Future Fire Man
profuse007
Gold - Posts: 2,015
Posted: January 10, 2004 at 2:08 PM / IP Logged
thats viper 791xv
the orange wire is not needed for rmeote start, starter kill, nor keyless. same thing for blue wire.
orange wire used to came along with a relay that use for starter kill. however the rs relay pack has a built in starter kill relay.
cut the starter wire from the vehicle, purple wire to starter side wire and green to teh key side starter wire.
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: January 10, 2004 at 2:10 PM / IP Logged
that blue white wire need to see ground for it to rs. its the initiate ground wire. theres an optional switch that came with it (flip switch).
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: January 10, 2004 at 2:12 PM / IP Logged
orange wire on the rs relay pack wire is teh accesory wire
Houston,TX
profuse007
Gold - Posts: 2,015
Posted: January 10, 2004 at 2:13 PM / IP Logged
orange wire on the rs relay pack wire is teh accesory wire. if you need a wire diagram for ur isuzu, check out the vehicle infomation in genernal info.
Houston,TX
fireman1321
Member - Posts: 20
Posted: January 11, 2004 at 12:53 AM / IP Logged
I am having some problems withsome connections... I need to know how to use the second starter wire for the remote start, and I also need to know where my Tach wire is... I think I have an idea of where it is, but it seems to not be the right wire. PLEASE HELP!
Future Fire Man
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
