94 F350 wiring diagram
Welcome Guest :)
michaelgalvin
Member -
Posted: January 13, 2004 at 9:23 AM / IP Logged
I need a wiring diagram for the Direct start CS 423 Remote starter on a 1994 F- 350. I will also be installing the same remote on a 2003 PT Cruiser which is loaded with options. I have only installed a couple of remote starters and they were bulldog security. Any help would be great.
Thanks, Mike
defective
Silver -
Posted: January 13, 2004 at 9:58 AM / IP Logged
Ford | Pickup F Series | 1994-1995 |
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | RED / LIGHT BLUE | IGNITION SWITCH HARNESS |
Ignition #1: | | RED / LIGHT GREEN | IGNITION SWITCH HARNESS |
Ignition #2: | | GRAY / YELLOW (# AWG) | IGNITION SWITCH HARNESS ** |
Ignition #3: | | GRAY / YELLOW-2WIRES | IGNITION SWITCH HARNESS ** |
Accessory: | | BLACK/ GREEN | IGN. SWITCH HARNESS |
Brake Light: | | LIGHT GREEN | (+) AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | TAN / YELLOW | AT COIL * |
Parking Lights: | | BROWN (+) | DRIVER KICK PANEL OR HEADLIGHT SWITCH |
Headlights: | | RED / YELLOW (+) | HEADLIGHT SWITCH OR BEAM SELECT SW. |
OEM Alarm Disarm: | | DARK GREEN/ PURPLE (-) | DRIVER KICK PANEL |
OEM Alarm Arm: | | N/A | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * Ignition Control Module (ICM) Located On Driver Rear Of Fender Panel. Powertrain Control Module (PCM) Located On Driver Firewall. SPOUT Connector Is Located Near ICM. SPOUT Connector Is A 2 Pin Plug With 2 PINK Wires, Either PINK Wire Is OK. ** See Note #127 - Ford Ignition Switch Connection Diagram. |
defective
Silver -
Posted: January 13, 2004 at 10:00 AM / IP Logged
Start: | | Yellow (+) | Ignition switch harness* |
Ignition #1: | | Blue (+) | Ignition switch harness |
Ignition #2: | | BLACK / YELLOW (+) | Ignition switch harness |
Ignition #3: | | N/A | |
Accessory: | | BLACK/ Orange (+) | Ignition switch harness |
Brake Light: | | WHITE/ Tan (+) | Brake pedal switch |
Tach Signal: | | BLACK/ Gray (AC) | Ignition coil |
Parking Lights: | | BLACK / YELLOW (+) | Drivers kick panel to the rear** |
Headlights: | | | |
OEM Alarm Disarm: | | | |
OEM Alarm Arm: | | | |
Diesel Glow Plug: | | N/A | |
Notes: | | *This vehicle is equipped With Chrysler's smart key engine immobilizer. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **Also found at the headlight switch. |
defective
Silver -
Monday, July 14, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
