2002 hyundai elantra stock alarm question
southpawboston
Member - Posts: 24
Posted: January 14, 2004 at 6:14 PM / IP Logged
newbie question:
i have an '02 elantra with factory alarm/keyless system. i want to determine whether or not i can add a pair of window modules (to roll all four windows up or down) to this system. here's what the stock system can do:
(-) armed output (starter kill relay), no auxilliary output
two-button remote:
    one button locks/arms, flashes lights once
    other button unlocks/disarms, flashes lights twice
that's about it. it's a basic stock alarm, but upgrading to a different alarm system is not an option. i'm fairly comfortable with relays, diodes and capacitors, but otherwise i'm no pro. here is the way i was imagining controlling the window modules, but i'm not sure such a thing is feasible:
press arm button two times. this causes the lights to flash two times. harness this event with the (-) armed output signal to trigger window roll-up.
press disarm button twice. this causes the lights to flash four times. harness this event with the (dead) armed output signal to trigger window roll-down.
is this at all feasible? is it possible to create a trigger (in general) by a specific sequence of pulses (the pulses being the lights flashing)?
schematics would be helpful.
thanks!
bmf1000d
Silver - Posts: 345
Posted: January 14, 2004 at 8:14 PM / IP Logged
every window roll up has its own way of working do you have a window roll up already. Most only require one neg input and the module does the rest.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
southpawboston
Member - Posts: 24
Posted: January 14, 2004 at 8:23 PM / IP Logged
i'm not sure what you're asking.
my factory system does not provide a roll-up or roll-down with the keyless entry.
the car does have power windows. i believe they operate by a standard two-relay setup.
the essence of my question was more along the lines of how do you create a trigger with a defined number or sequence of pulses.
also do the aftermarket window modules have built-in limit switches to prevent motor burn-out once the windows are rolled up or down?
bmf1000d
Silver - Posts: 345
Posted: January 15, 2004 at 12:09 AM / IP Logged
yes they do most of them anyways. All you need to do is have the module triggered by one neg pulse.
"Big" Mike
Double Take
Fremont, Ne
southpawboston
Member - Posts: 24
Posted: January 15, 2004 at 7:45 AM / IP Logged
i understand that the module can be triggered by a singly pulse. the problem is that if i allow a single pulse to trigger it, it will be triggered every time i arm or disarm the alarm. i can not have that. i have to create a trigger that is unique from simply arming or disarming the alarm.
