1992 bmw 325 ignition problem
jmmayrand
Posted: January 16, 2004 at 9:36 AM / IP Logged
Hi guys, I have a 92 325 and when it is getting warm the ignition is erratic ( like it's loosing it's fire). It is a low voltage system so each cylinder has its own coil. I used a insulator spray on them and no change. Any body as a solution for me? Thanks
meo
bmf1000d
Silver - Posts: 345
Posted: January 17, 2004 at 7:21 PM / IP Logged
coil per cylinder...what you might check to see if the casing is cracked on the coil. YOu have the 3.0L 6 right?
The casing on the coil that runs down to the plug is known to crack, so when it heats up or its hot the spark will arc off onto the cylinder and give you a misfire kinda feel.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
