98 cavalier, remote start, 2nd ignition
cerivera
Member - Posts: 15
Posted: January 16, 2004 at 11:00 AM / IP Logged
If you're installing a remote starter and your car has a 2nd ignition, do you have to connect it? IF so do you need a relay ...its a 98 cavvy and aladdin200 remotestart...thanks Cesar
Platinum - Posts: 12,488
Posted: January 16, 2004 at 11:29 AM / IP Logged
Yes you have to connect the 2nd igntion wire because this wire poweres up transmission computers on some vehicles and if the computer is not powered up, you can damage the transmission. Use this diagram to power up the 2nd IGN wire: http://www.velocitymotorsport.com/images/install_notes/2nd_ignition_relay.jpg
cpgoose
Gold - Posts: 1,098
Posted: January 16, 2004 at 12:05 PM / IP Logged
The Aladdin2000 doesn't come with 2 wires for 2 igntions? I've installed crappier units, and they've had 2 wires. I've never done an Aladdin, just curious :-)
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
Posted: January 16, 2004 at 12:34 PM / IP Logged
Use the GRAY wire in the P9 harness for your (-) 2nd IGN trigger. You must program this for 2nd IGN .
sroth140
Silver - Posts: 513
Posted: January 16, 2004 at 3:59 PM / IP Logged
for the relay, take the wire the member posted above this, and use it on terminal 85, then take 86 and 87 to constant 12v, and take 30 to the 2nd ign wire in the car.
cerivera
Member - Posts: 15
Posted: January 16, 2004 at 4:41 PM / IP Logged
Thanks guys for the info, much appreciated I think I'm squared away....cpgoose, the aladdin does have two ign wires, just wanted to be sure one wasnt an option!. thanks Cesar
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
