04 Grand Cherokee
Welcome Guest :)
allchromed01r1
Member -
Posted: January 17, 2004 at 9:01 AM / IP Logged
Anyone know where and the color of the databus wire for the door lock module in this vehicle????? help asap please and thank you.
chris
boomer_106
Silver -
Posted: January 17, 2004 at 10:29 AM / IP Logged
Jeep | Grand Cherokee | 2003-2004 |
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | Yellow (+) | Ignition switch harness* |
Ignition #1: | | Dk.Blue (+) | Ignition switch harness |
Ignition #2: | | N/A | Ignition switch harness |
Ignition #3: | | N/A | Ignition switch harness |
Accessory: | | RED / Black (+) | Ignition switch harness |
Brake Light: | | PURPLE / Tan(+) or WHITE/ Tan (+) | Drivers kick panel |
Tach Signal: | | See Note** | See Note** |
Parking Lights: | | Yellow (-) | Headlight switch |
Headlights: | | N/A | |
OEM Alarm Disarm: | | Lt.GREEN/ Orange (-) | Drivers door lock switch |
OEM Alarm Arm: | | N/A | |
Diesel Glow Plug: | | N/A | |
Clutch Bypass Wire: | | N/A | |
Notes: | | * This vehicle may be equipped with Chrysler's Smart Key Transponder Theft System only if the ignition key is gray. Use Universal Alarm Bypass Module part # 2x402 where X can by any number. ** On the 4.0L use any of the tan wires at the coil pack. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | Red & Pink/Black (+) | Ignition switch harness |
Starter Kill: | | Yellow (+) | Ignition switch harness* |
Ignition +12 Volts: | | Dk.Blue (+) | Ignition switch harness |
Dome Lights/Superv: | | See Note | *** |
OEM Horn: | | Gray/Orange (-) | Steering column harness |
Power Lock: | | See Note | ** |
Power Unlock: | | See Note | ** |
Trunk Release: | | N/A | |
Alarm Input Wire: | | See Note | *** |
Notes: | | **Use vehicle specific doorlock module part # 23544. ***The driver door trigger is Tan/Red at the driver door switch. The driver's rear door is Tan/Orange and the passenger's rear door is Tan / YELLOW at the BCM. The passenger's door is Tan/Red at the passenger's door switch. |
NowYaKnow
Gold -
Posted: January 17, 2004 at 10:42 AM / IP Logged
allchromed01r1 wrote:
Anyone know where and the color of the databus wire for the door lock module in this vehicle |
EDIT: Haven't done one of these in a while but I'm pretty sure it should be yellow/purple in pin 2 @ the diagnostic connector. It is located underdash near the fusebox. That small black fusebox cover also has a cutout where the diagnostic connector sits so look for that.
Wednesday, April 1, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
