2004 Tacoma, Need one wire color
mcloop
Member - Posts: 11
Posted: January 21, 2004 at 9:36 PM / IP Logged
Looking for the wire that is used for "unlock switch sense". I have pretty much have all other wire colors. But if you have them too, feel free to post just for confirmation.
Directions from the alarm manual say this;
Locate the vehicle wire that shows voltage or ground every time that the doors are unlocked using the door switch. Note: This wire must remain inactive when the driver's door is unlocked using the keyless entry remote.
Thanks, Mike
auex
Platinum - Posts: 5,041
Posted: January 21, 2004 at 10:24 PM / IP Logged
You are using a factory keyless upgrade right? The wire color is blue and is in the passengers door harness.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mcloop
Member - Posts: 11
Posted: January 21, 2004 at 11:42 PM / IP Logged
Yes, it's a factory alarm upgrade made by Code Alarm. I took it out of a 2004 Corolla because I installed an alarm/remote start combo. Now I have a 2004 Tacoma with just the keyless entry that I want to install it in.
Is the wire physically located in the drivers kick panel like it was in the Corolla? They basically have the same keyless entry system.
RufNUSD
Copper - Posts: 184
Posted: January 21, 2004 at 11:58 PM / IP Logged
Unlock Motor blue   5wi DKP, 12 pin plug in pin 11
Disarm Defeat blue   5wi PDP, 12 pin plug in pin 9
Power Unlock purple   -   front of fuse box, 22 pin plug These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door. Factory Alarm Disarm disarms with unlock
Someone pass me that bottle.
