03 BMW Z4 alarm wiring
Geoff Smith
Posted: January 23, 2004 at 5:42 PM / IP Logged
Does anyone have the wiring info for this car?? Many "Thanks" if you do.
bmf1000d
Silver - Posts: 345
Posted: January 23, 2004 at 5:46 PM / IP Logged
make sure to check all wiring for this car this does not look right but thats what the computer says if you get in there and see that none of the wires dont look the same then please do not use this diagram
WIRE COLORSLOCATION
12 VOLTS CONSTANTRED / YELIGNITION HARNESS
IGNITION 1GRNIGNITION HARNESS
ACCESSORY /HEATER BLOWER 1VIOIGNITION HARNESS
STARTERBLK/YELIGNITION HARNESS
PARKING LIGHTSGRY/VIO@HEADLIGHT SWITCH
DOMELIGHTBRN/WHT/YEL(-)BEHIND GLOVE BX
PWR DOOR LOCKWHT/RED / YEL(+)12 PINN CONN
PWR DOOR UNLOCKBLU/RED / YEL(+)BEHIND GLOVE BX (TYPE A)
TRUNK RELEASEBRN/WHT(-)BEHIND GLOVE BX
TACH SENSORBLKBEHIND INSTRU CLUSTERL
BRAKE
RED / BLU@SWITCH ABOVE BRAKE PEDAL
FACTORY ANTI-THEFT
 TRANSPONDER
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
