03 ford van wiring diagram needed
showtime
Member - Posts: 15
Posted: January 23, 2004 at 11:11 PM / IP Logged
if someone can help. i need the wiring diagram for a 03
ford econoline 350 van. thanx
boomer_106
Silver - Posts: 710
Posted: February 02, 2004 at 7:57 PM / IP Logged
Ford
Econoline
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
WHITE/ Pink (+)
Ignition switch harness
Ignition  #1:
RED / Green (+)
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
Gray / YELLOW (+)
Brake  Light:
Green (+)
Brake pedal switch
Tach  Signal:
WHITE/ Pink (AC)
At the CTO test connector*
Parking Lights:
Brown (+)
Buzzer or rear harness
Headlights:
N/A
OEM Alarm  Disarm:
Dk.GREEN/ Purple (-)
Theft module or drivers kick panel
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *The test connector is located by itself, labled CTO test connector above the brake booster on the driver side of the engine compartment.
Ford
Econoline
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Yellow (+)
Starter  Kill:
WHITE/ Pink (+)
Ignition  +12 Volts:
RED / Green (+)
Dome  Lights/Superv:
BLACK/ Lt.Blue (+)
At the courtesy light
OEM Horn:
Dk.Blue (+)
Horn relay underneath the dash
Power  Lock:
Red
Either kick panel**
Power  Unlock:
Brown
Either kick panel**
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ Lt.Blue (+)
Notes:
**This vehicle has reverse polarity door locks. See Note #203 - Reverse Polarity Door Lock Diagram. If the vehicle is equipped with factory keyless entry then use the small gauge Pink / YELLOW(+) and Pink/Green(+).
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
