Window Module help
gcherw
Member - Posts: 14
Posted: August 05, 2002 at 1:17 PM / IP Logged
I am installing a DEI 530T into my 2001 expedition. The passenger side window works as it should, however the drivers side doesnt work at all. Could this be due to the "auto" function of the window? If so, how do I rectify?
Platinum - Posts: 12,488
Posted: August 05, 2002 at 6:10 PM / IP Logged
You have to grab the wire at the motor for the driver's door, you can't grab it at the switch like the other doors. Here are the colors you want to wire into :
  • LF WINDOW UP------------wht/blk
  • LF WINDOW DN----------- orn/wht
gcherw
Member - Posts: 14
Posted: August 06, 2002 at 11:32 AM / IP Logged
Thanks Jeff...I grabbed the wht/blk and orn/wht at a connection point near the motor and still no luck...I'll try moving to the other side of the 2-wire harness...
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
