88 gmc pickup door locks
kwhite
Posted: January 27, 2004 at 1:51 PM / IP Logged
please help... I have a remote starter installed and it works fine, but I am trying to get the keyless lock/unlock to work. The locks have a 5 wire switch but when I hook up everything like the diagram says using 30 amp relays, it won't work. the truck is waiting in the garage and my wife is mad cause she parks her car in there and it's snowing. Help Please...
boomer_106
Silver - Posts: 710
Posted: January 27, 2004 at 2:41 PM / IP Logged
Did you doublecheck the wiring?  Below is what I have on that truck. Try checking the output of the relays with your meter when you operate the switch and see if it changes state.
GMC
Sierra Pickup
1988-1991
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
PURPLE OR YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
PINK
Ignition #2:
ORANGE
IGNITION SWITCH HARNESS (HEAT-A/C)
Ignition  #3:
N/A
Accessory:
BROWN
IGNITION SWITCH HARNESS (RADIO/WIPER)
Brake  Light:
WHITE
AT SWITCH ON BRAKE PEDAL BRACKET
Tach  Signal:
WHITE
AT DISTRIBUTOR OR IGNITION COIL
Parking Lights:
BROWN
(+) AT LIGHT SWITCH
Headlights:
YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * See Note #300 - GM Rear Wheel Drive Vehicles
GMC
Sierra Pickup
1988-1991
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED AND RED
Starter  Kill:
PURPLE OR YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
WHITE
(-) PIN SWITCH OR AT COURTESY LIGHT
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
L BLUE
DRIVER'S KICK OR BELOW SPEAKER **
Power  Unlock:
BLACK/ WHITE
Trunk  Release:
N/A
Alarm  Input Wire:
WHITE
Notes:
** See Note #203 - Reverse Polarity Door Lock Diagram.
kwhite
Posted: January 27, 2004 at 2:49 PM / IP Logged
the remote starter has this - green=lock   light blue=unlock . it also says it is for a negative door lock system. will it not work for me? do i have to wire it some weird way that isn't in one of the diagrams?
boomer_106
Silver - Posts: 710
Posted: January 27, 2004 at 2:57 PM / IP Logged
It is a reverse polarity doorlock system. The colors and connection location are what I have listed above. The following link will show you exactly how to wire it. Follow it closely and doublecheck as you go and you should be in business and the wife will be happy.   88 gmc pickup door locks -- posted image.
boomer_106
Silver - Posts: 710
Posted: January 27, 2004 at 2:58 PM / IP Logged
I guess I should remember to include the link. Sorry about that.
http://www.designtech-intl.com/Content/techsupport/documents/section04/note203.pdf
kwhite
Posted: January 27, 2004 at 3:04 PM / IP Logged
thank you, thank you, thank you.
boomer_106
Silver - Posts: 710
Posted: January 27, 2004 at 3:08 PM / IP Logged
Your Welcome
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
