2004 f150
mustangpony69
Member - Posts: 18
Posted: January 30, 2004 at 10:18 AM / IP Logged
I need to know if the dei 555f will work on a 2004 ford f150? I also would like to know what to do with the disarm defeat wire, not sure what it is used for!
Big Dog
Gold - Posts: 1,265
Posted: January 30, 2004 at 10:25 AM / IP Logged
Hey mustangpony69,
No the 555F won't work. You need a 555U or any other bypass that requires a key. This vehicle is equipped with a CRYPTO factory immobilizer.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Dolomite
Member - Posts: 12
Posted: January 30, 2004 at 10:32 AM / IP Logged
Use a 1L2Z  No key required.
mobiletoys2002
Gold - Posts: 1,050
Posted: January 30, 2004 at 10:33 AM / IP Logged
or if you dont want to give up a key buy a blank ford crypto key have it cut and and you program it in a matter of seconds, Now you have a new key for the car!! If you go this route I can tell u how to program the key ! YOu dont need any computers or tools for this just the blank key., when buying the blank key make sure it i sthe one with a blue bubbled out ford symbol,it should look exactly like the key you use now! cost should be like 18 bucks for the key tehn you will need a 555 u or youy can build your own for maybe 1 dollar! 2004 f150 -- posted image.
tjdurham
Copper - Posts: 180
Posted: January 30, 2004 at 12:56 PM / IP Logged
go to howard keys and get the key for $13 18005249199 no minimums same day shipping and build your own bypass with about 6 feet of 22 ga. wire and 1 relay and call it a day
tj
prdjr165
Copper - Posts: 293
Posted: January 30, 2004 at 9:09 PM / IP Logged
doe's Howard keys sell to the public?
mustangpony69
Member - Posts: 18
Posted: January 31, 2004 at 8:08 AM / IP Logged
how do you program your own keys?
mobiletoys2002
Gold - Posts: 1,050
Posted: January 31, 2004 at 1:34 PM / IP Logged
well what you need to do is have 2 keys that already start the car .
Then you will take the first key by itself and put in ignition turn igniton on wait till security light goes out now quickly get the second key and do the same thing,Now take that key out and do the same thing with new blank key wait till light goes out turn ignition off .The new key should be programed now it should start the car .
mobiletoys2002
Gold - Posts: 1,050
Posted: January 31, 2004 at 2:09 PM / IP Logged
programing has change a bit from earlier years now you have less time to cycle the keys in the ignition2004 f150 -- posted image. !
So have your keys within reach and ready take any keychains off the key so that it is only the key (no remote keyfobs)on the chain.
mustangpony69
Member - Posts: 18
Posted: January 31, 2004 at 7:47 PM / IP Logged
thanks for the quick reply! I will try it and see how I make out!
Thursday, November 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
