The horn doesn't work!
Loveforyou
Member - Posts: 39
Posted: February 01, 2004 at 4:31 PM / IP Logged
After i installed the remote starter combo alarm every thing work great but my horn do not work? my car is 95 maxima . I connect the disarm wire to the disarm wire in my car. but I can't firgure out yet why my horn won't work help please. thank
daniel2002p
Silver - Posts: 524
Posted: February 01, 2004 at 7:02 PM / IP Logged
check the fuses, and maek sure that you did not break any sire when installing it.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Teamrf
Gold - Posts: 1,031
Posted: February 01, 2004 at 11:58 PM / IP Logged
Yea check your wires, and make sure you didn't blow a fuse. If you seen any pretty sparks while installing the alarm you could of possibly blown a fuse.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Loveforyou
Member - Posts: 39
Posted: February 02, 2004 at 9:35 PM / IP Logged
thank you I'll check the fuse
Wednesday, January 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
