03 eclipse wiring info
clearman
Member - Posts: 46
Posted: February 06, 2004 at 1:48 AM / IP Logged
I need the wiring diagram for an 03 eclipse. I saw on here that there was the info for a 02 eclipse, is there any differences? Also, is it difficult to work with as far as door switches because it has the dome light delay?
mxxmikexx
Silver - Posts: 796
Posted: February 06, 2004 at 11:03 AM / IP Logged
Audiovox Tech Support 201999 FaxBack ID:
MITSUBISHI ECLIPSE 2003 2DR COUPE
Security Color Polarity Location
Battery WHITE/ RED & WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN (+) IGNITION SWITCH HARNESS
- Note JUNCTION CONNECTOR ON COLUMN AND IGNITION SWITCH WIRES CHANGE COLORS. CHECK BOTH SIDE OF
CONNECTORS.
Starter 1 BLACK/ RED (+) IGNITION SWITCH HARNESS
CONNECTORS.
All Door Trigger GREEN/ YELLOW (-) FUSE BLOCK ABOVE DRIVERS KICK
Trunk Trigger RED / GREEN (-) SAME AS DOOR TRIGGER
Hood Trigger BLUE/BLACK (-) FUSE BLOCK ABOVE DRIVERS KICK
Alarm Disarm DISARM WITH UNLOCK
Alarm Arm ARM WITH LOCK
Parking Lights GREEN / WHITE (+) FUSE BLOCK ABOVE DRIVERS KICK
Remote Start
CONNECTORS.
Ignition 2 BLUE/RED (+) IGNITION SWITCH HARNESS
Accessory 1 BLACK/ RED (+) IGNITION SWITCH HARNESS
CONNECTORS.
Anti-Theft Type TRANSPONDER
Anti-Theft Descript AN RF SIGNAL ACTIVATED SYSTEM
Key Sense BLUE/RED (-) IGNTION HARNESS
Neutral Safety BLACK/ RED (-) AT GEAR SELECTOR SWITCH
Tachometer BLUE (-) AT IGNITION COIL
Speed Sense WHITE/ BLUE (AC)
Brake Lights GREEN/ ORANGE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED / BLUE (+) AT GEAR SELECTOR SWITCH
Horn LIGHT GREEN/ BLACK (-) AT STEERING COLUMN
Doorlocks/Windows
Power Unlock ORANGE (-) DRIVERS KICKPANEL
PowerLock LIGHT GREEN/ BLACK (-) DRIVERS KICKPANEL
Driver Mtr Unlock GREEN/ RED (+) IN HARNESS IN DRIVERS KICKPANEL
Driver Mtr Lock LIGHT GREEN (+) IN HARNESS IN DRIVERS KICKPANEL
LF Window Up RED / BLACK (REV) MASTER SWITCH
LF Window Dn GREEN/ BLACK (REV) MASTER SWITCH
RF Window Up RED / WHITE (REV) MASTER SWITCH
RF Window Dn GREEN (REV) MASTER SWITCH
Convenience
Headlights-Lo VIOLET (-) HEADLIGHT SWITCH
Wipers-Lo GREEN/ RED (+) AT VEHICLE FUSE PANEL
Parking Brake YELLOW /GREEN (-) HANDBRAKE LEVER
Audio/Mobile Video
Battery RED / BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
LF Speaker (+) WHITE/ LIGHT BLUE
LF Speaker (-) BLACK/ BLUE
RF Speaker (+) WHITE/ RED
RF Speaker (-) BLACK/ RED
LR Speaker (+) YELLOW/BLUE
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
