horn honk with keyless entry lock button
erinh
Copper - Posts: 91
Posted: February 14, 2004 at 9:50 PM / IP Logged
i was wondering if its possible to make the horn honk when i lock the doors with the keyless entry remote. the car is a 96 toyota camry and the door lock wire is:
Door Lock      Light Green (-)
and the horn is:
Horn Wire      GREEN/ Black (-)        Steering Column
since they are both negative, could i just hook them both up to the lock wire from teh rs?
daniel2002p
Silver - Posts: 524
Posted: February 14, 2004 at 10:10 PM / IP Logged
yes you could but you need to use a diode because you do not want your door to lock when you honk your horn, but the other way around.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
bmf1000d
Silver - Posts: 345
Posted: February 14, 2004 at 10:13 PM / IP Logged
no you need to hook up a relay. the door lock does not have enough signal to trigger the horn.
87 ground
85 fused 12v
86 lock wire
30 hornwire
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
erinh
Copper - Posts: 91
Posted: February 15, 2004 at 1:43 PM / IP Logged
i thought i found the horn wire today, its the only GREEN/ black wire running down the steering column. but when i tested the wire while pushing the horn its voltage does not change. for a (-) wire does that mean it is grounded when the horn is actually being pushed and should be showing 12v when not being pushed? just want to test it with a multimeter and need to know what values i should see?
erinh
Copper - Posts: 91
Posted: February 16, 2004 at 12:04 PM / IP Logged
i dont' see any voltage on this wire with the keyoff when honk the horn, assuming i don't need key on. but this is the only GREEN/ black wire running down the steering column.
i took a picture, it has an arrow pointing to it plugging into a really long connector at the end of the steering column. hoping someone has worked on this model car before and can tell me if this is the right wire/if i'm in the right location?
horn honk with keyless entry lock button -- posted image.
