2000 toyota tunda remote start
dcllause09
Posted: February 16, 2004 at 5:27 PM / IP Logged
I need a full wiring diagram on a 2000  toyota tundra...iam installing a audiovox aps996a alarm with remote start...i know how to install the alarm portion but some of the remote start wires i dont have a clue...any info would be great.
thanks
soultinter
Copper - Posts: 170
Posted: February 16, 2004 at 6:11 PM / IP Logged
If you know how to test wires you can basically install it without using a wiring chart, all the heavy g wires that u need for 12v, ign, acc, start are at the column, just follow them from the ign cylinder, park lights are at the switch, and brake is at the switch above the pedal, tach is easy at the injector(opposite of common) or coil, there is an easy way to test if you go to coil. If you can install an alarm, you can easily use the same principals to do rm start.
draasch
Gold - Posts: 2,172
Posted: February 16, 2004 at 10:15 PM / IP Logged
Make:   Toyota
Model: Tundra
Year:    2000-01
This Database Was Last Updated On:    6/9/2003
Index #: 1604
Alarm
Constant 12 volts WHITE/ RED & WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter GREEN/ BLACK IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE (-) 9 PIN CONN DRIVER SIDE JUNCTION BLOCK
Trunk Pin Switch N/A
Parking Lamp GREEN (+) 12 PIN CONN DRIVER JUNCTION BLOCK
Power Lock WHITE/ GREEN 12 PIN CONNECTOR IN
Power Unlock RED / YELLOW DRIVER KICK PANEL * #209
* Child Safety Lock - RED / BLUE (-) In Same Connector As Door Locks. #209- See Child Safety lock diagram.
http://wiringinstructions.com/209.htm
Accessories
Window Up D\ LIGHT GREEN P\ RED / BLACK @ MAIN #211
Window Down R/ BLUE / YELLOW S/ RED / GREEN SWITCH
Ign Key Warn PINK/BLACK (-) STEERING COLUMN HARNESS
Trunk Release N/A
OEM Horn GREEN/ RED (-) STEERING COLUMN HARNESS *
Headlights GREEN/ YELLOW (-) AT HEADLIGHT SWITCH *
OEM Alarm Arm N/A NO OEM ALARM PRESENT
OEM Alarm Disarm N/A IN SCHEMATICS
* Located In 4 Pin Square Connector On Rear Of Junction Block In Behind Driver Lower Dash. #211 See Reversal Rest At Ground Power Window Circuit Diagram.
Remote Start
Tach Signal BLUE/WHITE TOP REAR OF ENGINE (8 CYL) *
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL **
Reverse Light RED / BLACK (+) BACK-UP RELAY BOTTOM LEFT OF J/B
Rear Window Defrost N/A
* 6 Cylinder - BLUE At ECM Behind Passenger Dash. ** Also Located in 13 Pin Connector Left Side Of Driver Junction Block.
if at possible, i would hook up the tach wire.
i did a 2002 and had a heck of a time getting it to start on the first time.
look on the passenger side fender under the hood for the "igniter". i think thats what it says on it. you should be able to find a tach signal there.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
