sure about sensors
cocain73
Member - Posts: 6
Posted: February 25, 2004 at 9:28 PM / IP Logged
i need to know for sure from someone if i hook up all of the same color wires on about three dual stage shock sensors would they all work or is this safe i really need some definate answers please help me out
new to the game
auex
Platinum - Posts: 5,041
Posted: February 25, 2004 at 11:02 PM / IP Logged
Depends on the type of alarm. I am sure it would be fine for the triggers but I would use a new source power and ground for the sensors.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
cocain73
Member - Posts: 6
Posted: February 25, 2004 at 11:07 PM / IP Logged
do you think i hooked up three more snsors to me existing one would it be safe
new to the game
auex
Posted: February 25, 2004 at 11:09 PM / IP Logged
For the triggers only, you should use new source of power and ground for the additional sensors, If you hook up the power and the grounds to the original sensor you will run the risk of blowing the power output. Also you should isolate each sensor with diodes.
cocain73
Member - Posts: 6
Posted: February 25, 2004 at 11:13 PM / IP Logged
i know this sounds funny but where can i get some diodes and what to do with them and what does it make the sensor do and if i dont use any would it hurt something help me out i know isound slow but i am trying to learn
new to the game
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
