Trunk trigger to door wire or hoodpin wire
cpgoose
Gold - Posts: 1,098
Posted: August 13, 2002 at 9:26 AM / IP Logged
Hi,  (viper 550esp)
So under the dash I have the door trigger wire that shows negative when the door is opened, so I connected it to the green wire from the module.  Peachy.
For the trunk trigger wire under the dash (that shows negative when opened), do I splice that into this same green wire for the doors, or do I splice that into
the gray wire for the hoodpin switch?  (I hope I don't need diodes, I've never used them before Trunk trigger to door wire or hoodpin wire -- posted image.  ) .  I don't have a separate wire for the trunk, right?
Big Dog
Gold - Posts: 1,265
Posted: August 13, 2002 at 2:16 PM / IP Logged
Hey cpgoose,
No, don't use the green nor the gray for trunk pin input.  Use the blue in the main harness (H1/6),  that's what it's there for.  Trunk trigger to door wire or hoodpin wire -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
cpgoose
Gold - Posts: 1,098
Posted: August 13, 2002 at 8:27 PM / IP Logged
Cool, thanks big dog.
mike simonelli
Member - Posts: 26
Posted: August 13, 2002 at 8:31 PM / IP Logged
Trunk trigger should have a diode on it at all times. If you tie it into the hood the light will come on when the hood is opened same with the doors use a diode.
cpgoose
Gold - Posts: 1,098
Posted: August 14, 2002 at 6:35 AM / IP Logged
Hmmm, so if I use the blue wire from the main harness for the trunk wire, I won't need a diode because I don't have anything else connected to it....correct?
Big Dog
Gold - Posts: 1,265
Posted: August 14, 2002 at 7:50 AM / IP Logged
Hey cpgoose,
You got it !!!!
