doorlocks 2000 dodge intrepid
lazyike
Member - Posts: 16
Posted: March 03, 2004 at 2:39 PM / IP Logged
Today had a customer come back and says that his doorlocks quit working after a week of working fine.(intalled a week ago).  I double checked all the wireing = O.K.   I then checked the resistors for the single wire doorlock 2.7k and 620 = O.K.   checked ground = O.K. checked fuses = O.K.  I then looked at the board on the remote starter unit and it had a burned spot on it. (crimestopper rs-999tw1).
What could be wrong that it fried the doorlock portion on the RS.
The only thing I could find that my installer did not do was tap into the doorwire at the bcm pin 5 junction c4, he WHITE/ dk. green wire.  He did find a door wire in the wireloom that runs to the rear of the car under the drivers sill plate WHITE/ lt. green wire.   would that matter??  It is still a doorlock wire.
daniel2002p
Silver - Posts: 524
Posted: March 03, 2004 at 4:58 PM / IP Logged
have relays been used in that install, if no relays have been used, then that could have burned out the rs unit.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
lazyike
Member - Posts: 16
Posted: March 03, 2004 at 8:40 PM / IP Logged
relays were used to convert a neg. door pulse to a positive.
lazyike
Member - Posts: 16
Posted: March 07, 2004 at 1:37 AM / IP Logged
any  thoughts?
lazyike
Member - Posts: 16
Posted: March 08, 2004 at 9:24 PM / IP Logged
anyone?
JakeJ
Member - Posts: 38
Posted: March 08, 2004 at 9:35 PM / IP Logged
I would check and make sure that the relays are switching to see if the signal is getting to them from the CS piece. If the relays are working with the lock and unlock then the problem is with the conection or resistance. If the relays are not woring you might have a bad unit.
Wyoming 12volt Enthusiast
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
