99 Tahoe, APS 996a
gearheads78
Member - Posts: 14
Posted: March 10, 2004 at 12:18 AM / IP Logged
Do to cost reasons and so I have control over the install I am about to install a alarm / remote start in my wifes truck. Its a 99 Tahoe. I have been practicing solder joints so I think all will be OK in that dept. The system is a Audio Vox APS996a. I will be adding DEI tilt / motion sensor, DEI battery backup siren and a piezo siren under the dash.
Is there anything I am going to run into that I need to be aware of on this install?
If all goes well on this one I will be trying my hand at my 04 Avalanche.
Javelin3o4
Copper - Posts: 239
Posted: March 10, 2004 at 1:35 AM / IP Logged
do you have a passlock II system in your truck? (GM's security built into the key) Cause if you do you will need a bypass module like DEI's 555T or 555L, also if your truck has the metal crash gaurd behind the lower dash panel that bolts in make sure when you put your wires back in they dont get pinched by that metal bracket because we had a tahoe at my shop come in that kept blowing ignition fuses because 1 wire got pinched and was shorting out.
Moderator - Posts: 12,488
Posted: March 10, 2004 at 9:02 AM / IP Logged
The Chevy's have an OEM disarm wire for the alarm that needs to see ground before remote start. The Tahoe is a very easy truck to work on ( lots of room under the dash ) and the tach is very easy to find as well in the engine bay. For the 2004 Avalanche I suggest getting a door lock interface/Passlock II bypass module for ease of installation. PM me for more information on this installation.
gearheads78
Member - Posts: 14
Posted: March 10, 2004 at 9:17 AM / IP Logged
Well I did order the DEI 555L for both trucks for the Passkey. I also ordered the DEI databus module for the 04 Avalanche so I should be good there.
I was more wondering anything I might run in to since it will be a first time. I have learned a lot hear just reading lots of past history posts.
gearheads78
Member - Posts: 14
Posted: April 01, 2004 at 12:11 PM / IP Logged
I am doing the install as we speak on a 99 Tahoe. Its a APS996a with DEI 555L.
-in the instuctions is says to pull main 12 volt power of two wires but only if total load does not exede 30A. There is a red and a RED / white 12v at the colunm. Are these ok to use or do I have to bring power from the battery?
-is this truck passlock I or passlock II
-anything else I might run in to during this install? I do build ans work on cars all the time but this is my first dive this deep in an electrical system.
thanks
gearheads78
Member - Posts: 14
Posted: April 01, 2004 at 12:13 PM / IP Logged
I just figured it out as paslock II but if I can get the other answers that would be great.
jfk51502003
Copper - Posts: 221
Posted: April 01, 2004 at 12:18 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / TAHOE / 1999 / Remote Start
[PRINT THIS PAGE]
12volts red + ignition harness
Starter yellow or purple + ignition harness
Second Starter
Ignition pink + ignition harness
Second Ignition white + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
Accessory orange + ignition harness
Second Accessory
Keysense
Power Lock lt. blue  either door boot
Notes: The 4 door versions are positive trigger, and the 2 door versions are 5-wire.
Power Unlock white  either door boot
Lock Motor gray  drivers door boot
Unlock Motor tan  drivers door boot
Parking Lights+ brown  headlight switch
Notes: Also found low in the drivers kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger purple - headlight switch
Dome Supervision white - underdash light
Trunk/Hatch Pin tied with doors
Hood Pin
Trunk/Hatch Release black or blk/wht  low in the drivers kick
Notes: Positive trigger on models with rear lift window, and 5 wire on models with cargo doors.
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer white  ECM
Notes: ECM is located on drivers side inner fender. Tach wire found in a black plug marked white.
Diesel wait to start wire is dk. blue (-) located at the instrument cluster.
Wait to start
Brake Wire white + at brake pedal switch
Parking Brake
Horn Trigger black - at column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module:Required: YesType: Passlock 2Part #: 555L or 555T
Notes: N/A
99 Tahoe, APS 996a -- posted image.
gearheads78
Member - Posts: 14
Posted: April 04, 2004 at 4:52 PM / IP Logged
OK I am on the downhill side of the install. I only get to work a few hours at a time so its taking a while.
One last question, on the diagram above it says lock motor and locks are different. So what wires do I use? The lt blue/ white or the grey and tan?
The alarm is limited to 300mA on its RED / green outputs and I don't want to burn it up the first time I try it.
bmf1000d
Silver - Posts: 345
Posted: April 04, 2004 at 5:27 PM / IP Logged
you use the lt blue and white for lock unlock the others are if you want to do driver door priority
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
