1999 altima
lenster40
Member - Posts: 10
Posted: March 15, 2004 at 11:04 PM / IP Logged
I need a diagram and special instructions on installing a remote start on a 99 nisssan altima, do i need a relay to wire between the both the starter wires? if so,do i need to wire in a diode?
Please help
Len
lenster
draasch
Gold - Posts: 2,172
Posted: March 15, 2004 at 11:22 PM / IP Logged
Make:   Nissan
Model: Altima
Year:    1999
Alarm
Constant 12 volts WHITE/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) WHITE 20 PIN CONN. IN DR. KICK PANEL
Trunk Pin Switch RED (-) AT LIGHT IN TRUNK *
Parking Lamp RED / BLUE (+) AT HEADLAMP SWITCH **
Power Lock GRAY AT "SMART ENTRANCE #201
Power Unlock PURPLE CONTROL UNIT" ***
* RED (-) Trunk Pin Wire Is Also Located At "Smart Entrance Control Timer". ** RED / BLUE (+) Park Light Wire Is Also Located At Fuse Block In Driver Kick Panel. #201- See Negative Pulse Door Lock Diagram. *** "Smart Entrance Control Unit Is A BLUE Module Which Is Located Behind The Driver Dash To The Right Of The Steering Column.
Remote Start
Tach Signal L GREEN/ ORANGE (-) WHT 18 PIN CONN. NEXT TO PASS KICK
Ignition #2 BLACK/ PINK IGNITION SWITCH HARNESS (BLOWER)
Ignition #3 N/A
Accessory WHITE/ BLUE IGNITION SWITCH HARNESS
Neutral Safety GREEN/ ORANGE (-) AT INHIBITOR SWITCH
Brake Light RED / GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light GREEN (+) AT INHIBITOR SWITCH
Rear Window Defrost GREEN/ BLACK (-) AT REAR WINDOW DEFOGGER SWITCH
Cold Start Wire - BLACK/ BLUE.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
