Is there a mistake here?
markcars
Silver - Posts: 662
Posted: March 17, 2004 at 9:52 PM / IP Logged
Is the diode polarity reversed/wrong in this?
I bought 2 of these about a month ago but think the drawing has a mistake. Looks like the sensor has -ve triggers but diodes are facing the wrong way.
Am I right or the drawing is right?
Is there a mistake here? -- posted image.
Teamrf
Gold - Posts: 1,031
Posted: March 17, 2004 at 10:05 PM / IP Logged
I think that diagram is right...that diode will only allow that current from the shock sensor to go out so it won't come back and trigger that shock sensor causing false alarms.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
markcars
Silver - Posts: 662
Posted: March 17, 2004 at 10:18 PM / IP Logged
Teamrf, did you check the trigger? It is -ve trigger, not +ve trigger. So the "current" that you are talking about really does not go from the sensor out, but its a -ve. If it was +ve then I think the diagram is right, but since the trigger is -ve I feel the diode must be reversed from what is shown in the diagram.
Can you ask someone to make sure?
Also can someone else check this too please?   I want to be 100 percent sure. Thanks.
auex
Platinum - Posts: 5,041
Posted: March 17, 2004 at 10:35 PM / IP Logged
Yes it is backwards. Line should be facing the shock sensor.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
markcars
Silver - Posts: 662
Posted: March 18, 2004 at 4:19 AM / IP Logged
Thanks a lot auex for confirming. After reading the first response, I was beginning to think my brains weren't functioning too well anymore. I can continue now.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
