90 Chevy 3/4 ton silverado Remote starter
fjames623701
Posted: March 18, 2004 at 2:42 PM / IP Logged
Hello all,
I have a remote starter in my PU 90 Chevy 3/4 ton silverado. The remote starter worked fine until I put a MSD ignition box 6A. Now the truck will crank and start but then it will shut off in about 3 or 4 sec. then it will start again and same thing. I know I can tie into the fuel injection for the signal switch but what wire is it??? any help apreciated
Teamrf
Gold - Posts: 1,031
Posted: March 18, 2004 at 2:55 PM / IP Logged
What is an MSD ignition box 6a?
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
fjames623701
Posted: March 18, 2004 at 3:03 PM / IP Logged
 6A is an aftermarket electronic Multiple Spark Distributer box. It sends a bunch of sparks to the plug instead of just one. I installed it so that later on when I get the supercharger for her I can use the box to retard my timeing.
FullForce
Copper - Posts: 103
Posted: March 18, 2004 at 8:25 PM / IP Logged
i would just set that sucker to tachless, unless you live where it gets very cold
draasch
Gold - Posts: 2,172
Posted: March 18, 2004 at 8:42 PM / IP Logged
fjames, i sent you an e-mail. see if that info works. if not try like they said and go tach less....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
