Clifford RS 3.5 not resetting
04Sahara
Member - Posts: 12
Posted: March 21, 2004 at 8:37 PM / IP Logged
According to the manual, the RS 3.5's led is supposed to blink the # of times that corresponds with the zone that caused the last alarm and it's supposed to STOP blinking when you start the car again. Mine isn't resetting - it's blinking zone 1 or 2 (shock or proximity) as I'm driving. The only way to make it stop is to pull the fuse for the brain and plug it back in. It seems that I didn't connect any wire to that would let the brain know that the car is on - I can turn my alarm on while driving and it keeps going off (i guess b/c of the radar or shock sensors). HELP?!!
I installed the clifford rs 3.5 in my jeep. I didn't install anything that dealt with remote start. I can't find wiring info for a 04 Wrangler so I'm wondering if I should just take the alarm back and wait for the 04 wiring diagram to come out before I take it to get one installed for a lot more $$$. What do you think? I've spent more than 2 days and Circuit City/Best Buy/CarToys/Mobile1 say they can do it in 4-5 hours including remote start for either the clifford rs 3.5 or viper 761.
Help?!!! This was supposed to be easy!
Javelin3o4
Copper - Posts: 239
Posted: March 21, 2004 at 10:01 PM / IP Logged
here's the info for a '03 wrangler it may be the same.
12volts
pink/black & red
ignition harness
Starteryellow + ignition harness
Second StarterN/A
Ignitionblue + ignition harness
Second IgnitionN/A
Third IgnitionN/A
AccessoryBLACK/ orange + ignition harness
Second AccessoryBLACK/ green + ignition harness
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+BLACK / YELLOW + headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggeryellow - headlight switch
Dome Supervisionuse door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding DoorN/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometergray ac ignition coil or coil pack
Wait to startN/A
Brake WireWHITE/ tan + brake pedal switch
Parking Brake
Horn TriggerRED / yellow - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
bmf1000d
Silver - Posts: 345
Posted: March 21, 2004 at 10:32 PM / IP Logged
Start:
Yellow (+)
Ignition switch harness
Ignition  #1:
Blue (+)
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
BLACK/ Orange (+)
Brake  Light:
WHITE/ Tan (+)
Brake pedal switch
Tach  Signal:
Gray (AC)
Ignition coil
Parking Lights:
BLACK / YELLOW (+)
Headlight switch
Headlights:
N/A
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Constant  +12 Volts:
Pink/Black & Red (+)
Starter  Kill:
Yellow (+)
Ignition  +12 Volts:
Blue (+)
Dome  Lights/Superv:
Yellow (-)
Headlight switch
OEM Horn:
RED / Yellow (-)
Steering column harness
Power  Lock:
N/A
Power  Unlock:
N/A
Trunk  Release:
N/A
Alarm  Input Wire:
Yellow (-)
Headlight switch
Notes:
**Vehicles without power door locks See Note #204 Adding Door Lock Actuators.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
auex
Platinum - Posts: 5,041
Posted: March 21, 2004 at 10:35 PM / IP Logged
The alarm gets it's ignition feed through the remote start relays. If these didn't get hooked up then the alarm doesn't know that the ign has been turned hence not resseting itself.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Teamrf
Gold - Posts: 1,031
Posted: March 21, 2004 at 10:55 PM / IP Logged
I've found some problems in the 3.5 as well as the RSIII. I hear they are suppose to be coming out with a 4.5 here pretty soon. My 3.5 doesn't even report what is going on with my car anymore.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
sroth140
Silver - Posts: 513
Posted: March 21, 2004 at 11:06 PM / IP Logged
you have to have the ignition wires hooked up.  if you have it in your vehicle and you arent using it for remote start, then i take it you are using it for alarm.  usually alarms need to have the starter wire cut, and have ign and 12v hooked up.  thats basically  a remote start right there.  DEI products need the door trigger signal, and ign hooked up to do the following:  Learn remotes, enter and select programming features, program the tach wire, enter and exit valet mode, operate the IGNITION controlled door locks.... basically everything its ment to do.
as far as the remote not reporting anything, try unplugging both ends of the antenna wire, from the antenna and the brain.  then plug them back in.  ive had that work twice.
as far as coming out with a 4.5, the 3.5 went on clearence at Best Buy, i think we are supposed to be getting viper now.  there have been a few viper SKUs added to our system.
MECP certified installer
04Sahara
Member - Posts: 12
Posted: March 22, 2004 at 8:39 AM / IP Logged
Thanks for the information guys. I looked at the RS 2.5X and noticed that the H1 has a wire that is unused on mine that is for run/start power. I'm guessing that that's how the 2.5 knows the vehicle is on and from what you guys said it's obvious that the 3.5 uses the stuff on it's remote start circuit.
I think I'm just gonna go ahead and return this - I don't like messing with the starting system. I'll leave that to you experts.
