no start, 1999 1500 silverado
nyfyrman
Posted: March 21, 2004 at 9:12 PM / IP Logged
I installed a pager alarm/ remote starter in a 1999 new style 1500 silverado 4WD. I cant get the truck to remote start. It cranks but has no ignition. I hooked up the 2 ignition wired listed in this forums wiring diagram to the remote starters 2 ignition wires. Any ideas?
mikynunu
Member - Posts: 6
Posted: March 21, 2004 at 9:50 PM / IP Logged
did u bypass the passlock II system in the car. this not being by passed will cause the truck to crank but not turn over. you can either use dei parts 555L or 555t or a relay with the correct resistor
hope this help you
auex
Platinum - Posts: 5,041
Posted: March 21, 2004 at 10:32 PM / IP Logged
Is the orange "security" light lit up after you try to remote start or otherwise?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
sroth140
Silver - Posts: 513
Posted: March 21, 2004 at 11:08 PM / IP Logged
sounds like somebody needs a 555L.
MECP certified installer
