99 Pathfinder remote help
rmn6
Member - Posts: 16
Posted: March 24, 2004 at 12:41 AM / IP Logged
I have a 1999 Nissan Pathfinder and my alarm remote died. I replaced it but I need the information to program this remote for my truck.
draasch
Gold - Posts: 2,172
Posted: March 24, 2004 at 7:12 AM / IP Logged
is it a factorty remote or aftermarket??
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: March 24, 2004 at 11:51 AM / IP Logged
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
draasch
Gold - Posts: 2,172
Posted: March 24, 2004 at 1:46 PM / IP Logged
jeff, not sure what you said in your post................
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted: March 24, 2004 at 1:59 PM / IP Logged
MUCH better. Had to do some editing there but it's there now. 99 Pathfinder remote help -- posted image.
draasch
Gold - Posts: 2,172
Posted: March 24, 2004 at 2:18 PM / IP Logged
is the programming instructions that you posted for the pathfinder only???
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted: March 24, 2004 at 6:41 PM / IP Logged
Yes, it's for the Pathfinder only. I have other's for Nissan. The programming instructions are also year sensitive so this procedure will not work for 2000 - 2003 Pathfinders but will work for the 1996 - 1999 Pathfinder's.
rmn6
Member - Posts: 16
Posted: March 25, 2004 at 1:22 AM / IP Logged
Thank you Jeff. I appreciate the help.
