2003 Passat
benw
Posted: March 26, 2004 at 12:18 AM / IP Logged
I'm installing a remote starter in a 2003 VW Passat. I'm looking for a diagram if anyone has one, and also, do all '03 Passat's have an immobilizer?
Thanks!!
Ben
Clairmont Auto Group
draasch
Gold - Posts: 2,172
Posted: March 26, 2004 at 7:39 AM / IP Logged
if you have a factory security system here is a part you may want...VWDL or a TBKIII just to by pass the key(requries a key)
Make:   Volkswagen
Model: Passat
Year:    2003
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK IGNITION SWITCH HARNESS
Starter RED / BLACK IGNITION SWITCH HARNESS
Dome Light RED / BLACK (-) DRIVERS A PILLAR
Trunk Pin Switch BROWN / GREEN (-) DRIVER KICK PANEL
Parking Lamp GRAY/BLACK (+) AT HEADLIGHT SWITCH
Power Lock RED / GREEN DRIVERS KICK #201
Power Unlock RED / BLUE PANEL
#201 See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal GREEN/ BLUE IN HARNESS FROM INSTRUMENT PANEL #239
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #3
Accessory YELLOW/BLUE IGNITION SWITCH HARNESS
Neutral Safety
Brake Light RED / BLACK (+) AT SWITCH ABOVE PEDAL
Reverse Light RED / BLUE (+) DRIVERS KICK PANEL
Rear Window Defrost
#239 See Immobilizer Bypass Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
chriswallace187
Gold - Posts: 1,661
Posted: March 27, 2004 at 12:34 AM / IP Logged
I'm pretty sure all '03 Passats have an immobilizer, so you'll need to bypass that. I've done '01 and '02 Passats (1 each) and both had an immobilizer.
Also, when I did those I was using a DEI 555U bypass module(a universal type with an antenna ring that goes around the key cylinder) and the bypass would not work with the antenna ring placed in the normal fashion; I had to cut the antenna ring off and solder the wires directly into the factory immobilizer wiring. Just giving you a heads up on that - I'd recommend you use that 555U bypass if possible, because I know it worked on that particular car.
Plus I didn't want you to have to find out like I did that the regular way didn't work after working 3 hours overtime with a piss-drunk, bitchy customer asking why the hell her remote start's not working every 45 seconds or so 2003 Passat -- posted image. Man that was a fun experience.
Post back and let us know how everything goes.
benw
Posted: March 29, 2004 at 11:03 PM / IP Logged
thanks for all the help!!!
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
