alarm locks doors when disarmed
bigt_45
Copper - Posts: 48
Posted: March 30, 2004 at 9:37 AM / IP Logged
My gf has a 1995 integra with a code alarm.  It locks the doors, instead of unlocking them, when the car is disarmed of the ignition is turned off.  I know that one of the wires is wrong, but im not sure which one.  There are three wires that control the lock/unlcok.  I think that one is the negative pulse and one is the positive pulse.  Then there is a third wire that is diagramed as "2nd unlock".  Any help from anyone would be greatly appreciated.
draasch
Gold - Posts: 2,172
Posted: March 30, 2004 at 12:02 PM / IP Logged
you should only need two wires for the door locks on that car. do the door locks work the right when you arm the system???/if so you have the third wire hooked uo to the lock side instead of the unlock side...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Monday, July 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
