96 ford ranger alarm installation
haole
Posted: April 18, 2004 at 4:45 AM / IP Logged
I am part way through the installation of a alpine 150r alarm in my 96 ranger and running into some strange problems.  I am piggy-backing the factory unit by splicing all the corresonding wires, so some of the trouble may be an incorrect info from my service manual.  Currently my problems are:
-factory unit doesn't arm/disarm with alpine EXCEPT when doors are open (wtf?)
-the door switch and dome light connections are reading constant voltage the whole time, so the door trigger is not working and dome light doesn't come on when unlocked
I am not aware of a factory arm and disarm input, are there any way around this?  Right now I have lock and unlock circuits doing the arming.  Thanks for any halp or advice!
-jesse
draasch
Gold - Posts: 2,172
Posted: April 18, 2004 at 7:27 PM / IP Logged
Make:   Ford
Model: Ranger
Year:    1996
Alarm
Constant 12 volts YELLOW (4) IGNITION SWITCH HARNESS
Ignition 12 volts L GREEN/ PURPLE IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) 84 PIN SQUARE CONN. BEHIND DR. DASH
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH (W/O OEM ALARM) *
Power Lock PINK / YELLOW 16 PIN CONNECTOR IN #201
Power Unlock PINK/L GREEN DRIVER KICK PANEL
* With OEM Alarm Parking Lights Are WHITE/ BLACK (+) At Headlight Switch. #201- See Negative Pulse Door Lock Diagram.
Remote Start
Tach Signal TAN / YELLOW AT POWERTRAIN CONTROL MODULE *
Ignition #2 GRAY / YELLOW IGNITION SWITCH HARNESS ** #235
Ignition #3 GRAY / YELLOW IGNITION SWITCH HARNESS **
Accessory BLACK/ L GREEN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light L GREEN (+) AT SWITCH ABOVE BRAKE PEDAL BRACKET
Reverse Light BLACK/ PINK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost N/A
* Powertrain Control Module Located On Passenger Rear Of Engine Compartment On Firewall. TAN / YELLOW Wire Also Located In Round Single Pin Tach Test Connector On Driver Rear Of Engine Compartment. ** Both GRAY / YELLOW Wires Must Be Powered For Heat/Ac To Operate. #235- See Powering Extra Ignitions Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
