1998 Pathfinder Rear Hatch
CT18fireman
Member - Posts: 15
Posted: April 18, 2004 at 9:05 PM / IP Logged
Have a problem that suddenly popped up on my Nissan.  Have a Viper installed for three years now.  Just yesterday when I arm the system the rear hatch locks (along with the rest of the loacks) and then unlocks.  I can hear it as well as open the hatch which then sets off the alarm.  If I lock the doors using the key in the door or interior switches, the hatch stays locked.  All other functions seemed to be working fine.  Any thoughts?
draasch
Gold - Posts: 2,172
Posted: April 18, 2004 at 10:58 PM / IP Logged
double check the door lock wires...
Power Lock L GREEN/ RED 16 PIN WHITE CONNECTOR ** #201
Power Unlock BROWN IN DRIVER KICK PANEL
** Door Locks Also Located At "Smart Entry Control Timer" Behind Left Side Of Driver Dash On Right Side Of Fuse Block. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
