Derringer Alarm Malfunction
jagislander
Posted: April 19, 2004 at 2:34 PM / IP Logged
I bought a car with a Derringer alarm (installed in 1984) –
There are two LED lights on the steering column on the opposite sides of each other at the ignition point.  These lights continuously flash; and I think are supposed to stop flashing and burn solid or go out before the car can be started. Instead of burning solid or shutting off they continue to flash when I push the button located in the glove box.  I no longer hear the click that sounded when the button was pushed; leading me to believe a relay may have quit. The button in the glove-box has a single purple wire coming from the rear of the box to the button then grounds out. At this point I’d like to disable or remove the alarm system, but unable to find any information specific to it.
Is there a way to reset the system using the button in the glove box? Or are there any specific procedures to using this button?  Also, the car battery had been dead for about three months before attempts to start it.
Is anyone able point me to a solution for this situation?
Thanks, jag
draasch
Gold - Posts: 2,172
Posted: April 19, 2004 at 2:39 PM / IP Logged
all valet must have two wires....check the rear of the switch and see if one of the wires have been disconnected....or look under the drivers side dash and find the main unit....once you find it, unplug all of the wires....you should be set ...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
desh187
Copper - Posts: 310
Posted: April 19, 2004 at 2:40 PM / IP Logged
chances are,your remotes have lost memory and i would suggest pulling this unit out since its too old and replace it with someting current where you do not have a memory loss problem.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
