AutoPage RF-305 Alarm
frumiami
Posted: April 27, 2004 at 2:48 PM / IP Logged
           AutoPage RF-305 Alarm -- posted image.   Hi, I posted this yesterday and didn't get a reply. I just need someone to point me in the right direction, please. I bought the car from a dealership and they didnt know anything about the alarm. Im pretty savy when it comes to technical things, I am an office machine Tech.  The alarm appears to have been installed professionally, I see the relays and the brain for the alarm. Any idea where i might get a manual? And I would take it in to get repaired, but i just quit my job and money is tight now. I don't think it's a big deal, any ideas would be greatly appreciated.          AutoPage RF-305 Alarm -- posted image.
      AutoPage RF-305 Alarm -- posted image.      Hi, I've recently bought a 97 Honda Civic Ex. It is a 5 speed with power everything. I knew it had an alarm when I bought the car but it doesnt work. There is a fuse holder near the battery that is inline with the main power wire for the alarm, with the fuse missing. If I put a fuse in it, the alarm goes off and will not shut off, even when I press the buttons on the transmitter. I've checked all of my fuses inside and out, everything is in order. I've taken the panel off near my fuse box to trace some of the wires coming from the brain of the alarm. I don't see anything out of order, any ideas? I do not have a manual or anything with the alarm, so I don't know how to program it or anything. I just need to find out why the alarm is going off with the fuse inserted and I think it should work fine.
Thanks in advance,AutoPage RF-305 Alarm -- posted image.
Shawn
draasch
Gold - Posts: 2,172
Posted: April 27, 2004 at 4:31 PM / IP Logged
look for a hidden switch or push button under the dash....you should be able to over ride the alarm by using the switch.....try a search for that unit on the web...you should be able to find a manual for it
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
