04 Jeep Liberty, False Door Trigger
deviousjoker
Copper - Posts: 102
Posted: April 27, 2004 at 5:36 PM / IP Logged
I just installed a Code Alarm Pc4200 in a 04 liberty and had some problems with the door trigger.  Directechs said tan for drivers and tan/white for passenger door.  the liberty has 4 doors.  I look in the blue plug and found tan, tan / YELLOW, tan/red, tan/orange.  all these wires tested as negative triggers for each door.  I isolated all the triggers with diodes and when i armed the jeep the alarm went off about 20 seconds later.  after trying to figure it out I just wire it to the domelight and it works fine except the delay but no big deal.  just wonding if anyone has had this issue or know why this is happening.
desh187
Copper - Posts: 310
Posted: April 28, 2004 at 12:30 AM / IP Logged
Did you use 1 amp diodes with the band side facing oem wires?
raydawg357
Silver - Posts: 769
Posted: April 28, 2004 at 7:29 AM / IP Logged
Your domelight delay is probably setting off your alarm.  Try connecting the domelight supervision to your door trigger
Do it right the first time
Greg S
Member - Posts: 31
Posted: April 28, 2004 at 9:45 AM / IP Logged
The trigger lines drop to ground after a time.  Jeep started using this system with the Grand Cherokee back in the late 90s.  Just leave it on the dome light trigger and you should be fine.
Greg Stoddard
