DEI 451M help
Pooreclipse
Copper - Posts: 75
Posted: May 01, 2004 at 6:39 PM / IP Logged
Can someone tell me what is the easiest way to control my pair of 2 wire aftermarket actuators.  They will be tied and powered together.
The alarm send out use + - to lock and - + to unlock.
Just want to use the 451M as dual relays to control 2 wire actuators.. not 5 wire actuator and all that stuff.
auex
Platinum - Posts: 5,041
Posted: May 01, 2004 at 8:05 PM / IP Logged
Plug the three pin plug directly into dei lock port. Purple wire is +12V, whit and brown go directly to ground, and the blue and green are the lock outputs. You need to test the actuators with the blue and green wire becuase it will depend on how you mount the actuators as to which wire will be lock and unlock.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
sroth140
Silver - Posts: 513
Posted: May 02, 2004 at 2:45 PM / IP Logged
thats it
if you get blue and green backwards with the actuator wires, your lock will unlock them and vise versa.  just filp wires and youll be good to go.
MECP certified installer
