1988 Ford F150 Alarm install
rghrdr18
Member - Posts: 28
Posted: May 11, 2004 at 11:42 PM / IP Logged
I am installing an alarm into a F150 Custom, and looking up the alarm diagram for my truck, i found that none of the wires match. I am trying to find the Constant 12V, (which i found 2 wires that ran 12V with my DMM), and the starter wire. Please help.
profuse007
Gold - Posts: 2,015
Posted: May 12, 2004 at 12:58 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|yellow              |+ |ignition harness            |
|          STARTER|RED / lt. blue        |+ |ignition harness            |
|        IGNITION|RED / lt. green       |+ |ignition harness            |
|        ACCESSORY|gray / YELLOW        |+ |ignition harness            |
|       POWER LOCK|BLACK/ orange        |5wi|either kick panel *1        |
|     POWER UNLOCK|pink/green          |5wi|either kick panel *1        |
| PARKING LIGHTS +|brown               |   |lt switch or dr kick        |
|       HEADLIGHTS|RED / yellow          |+ |at switch                   |
|     DOOR TRIGGER|BLACK/ blue          |+ |driver kick panel           |
|       TACHOMETER|tan / YELLOW *2       |   |at coil                     |
|       BRAKE WIRE|lt. green           |+ |brake pedal switch          |
|     HORN TRIGGER|dk. blue            |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|red - yellow        |A |in drivers door             |
| RF WINDOW UP/DN|RED / blk - yel/blk   |A |in drivers door or dkp      |
Notes:
*1 ESSENTIAL to use driver's switch when testing for switch and motor sides.   *2 On diesel trucks use WHITE/ black at the alternator for tach. Also the wait to start wire is BLACK/ pink (-) at the warning light on the dash or the glow plug controller on the center rear of the engine.
Houston,TX
rghrdr18
Member - Posts: 28
Posted: May 12, 2004 at 10:37 AM / IP Logged
That wiring diagram does not match any of the colors i have on my truck's iginition harness. Please help.
profuse007
Gold - Posts: 2,015
Posted: May 12, 2004 at 1:27 PM / IP Logged
-does any of those wire match at all?
-finding wires at the iginition harness is really easy. look at the thick guage wire.
starter: 12volt (+) only when crank
ignition/acc: 12 volt(+) when key turn once-acc. 12volt when key turn twice-ignition
thats it!!!!
Houston,TX
rghrdr18
Member - Posts: 28
Posted: May 12, 2004 at 1:30 PM / IP Logged
No, none of the wires match. I printed up the wiring diagram yesterday from this web site and looked at the wiring harness in the truck, and nothing matched. But, I will try that today. Thanks for the help.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
