Domelight Supervision on 97 K1500 wireloc
WillTS
Copper - Posts: 65
Posted: May 19, 2004 at 9:11 AM / IP Logged
Does anyone know where I would find the domelight supervision wire for a 1997 Chevy K1500? I am trying to hook it up because when they installed it they never hooked it up. I know on the alarm it gets connected to H1/4 -200mA domelight supervision output. Thanks
Will
draasch
Gold - Posts: 2,172
Posted: May 19, 2004 at 9:15 AM / IP Logged
you will take the wire from the alarm and wire it to a relay. then it will hook up to your door trigger wire....
i think you have a neg door trigger on that truck.
if the output wire from the alarm is neg. then wire it like this:
86 12 volts fused (10 amp)
85 wire from alarm
87 ground
30 to dome light wire (truck's door trigger wire)
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
raydawg357
Silver - Posts: 769
Posted: May 19, 2004 at 9:30 AM / IP Logged
What type of alarm are you using?  Most come with a dome light supervision wire that you need to connect to your door trigger wire.
Do it right the first time
WillTS
Copper - Posts: 65
Posted: May 19, 2004 at 9:42 AM / IP Logged
It is a Clifford Matrix RS2. When I connect that relay, and disarm my system, the interior light will come on correct? Will that cause the alarm to think that I opened a door? If so would that mess up the automatic arming of the alarm? Thanks
Will
draasch
Gold - Posts: 2,172
Posted: May 19, 2004 at 9:46 AM / IP Logged
it will turn on the dome light... the rearm will start working after the dome light turns off...should be 30 arming timer
Good Luck
David
Ace Security
813-376-9778
Tampa
WillTS
Copper - Posts: 65
Posted: May 19, 2004 at 9:57 AM / IP Logged
That makes sense. I think I will go ahead and do it. I just have to go and get another relay and the socket for the relay. Thank you!!
Will
Will              Just my $00.02
97 Chevy K1500 5.7L w/ Clifford Matrix RS2
BTW I am not a professional(well at procrastination maybe)
Be Gentle, I'm new to this :-)
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
