transponder
mobiletoys2002
Gold - Posts: 1,050
Posted: September 01, 2002 at 8:40 PM / IP Logged
i got permission from the customer to bypass the transponder in his car can it be done.??and if so how do i bypass it??
Platinum - Posts: 12,488
Posted: September 01, 2002 at 8:59 PM / IP Logged
Do you mean bypass it permanently ?? What car and what year ?
mobiletoys2002
Gold - Posts: 1,050
Posted: September 01, 2002 at 9:24 PM / IP Logged
yes what can be done?????? 99 acura tl .
mobiletoys2002
Gold - Posts: 1,050
Posted: September 03, 2002 at 6:43 PM / IP Logged
anyone??????
Posted: September 03, 2002 at 9:21 PM / IP Logged
Introduce the chip into the Immobilizer module without a ground out when running wire to activate a relay. This will bypass the Immobilizer at all times. Be warned though... make sure that if you do this that the customer uses keys that do not have another chip otherwise two chips sending the same information will eventually confuse the system to the point of crashing.
