adding remote start to factory alarm
crash1ny
Member - Posts: 7
Posted: May 23, 2004 at 8:33 PM / IP Logged
hi i have a 2001 saturn L200 with factory alarm wanted to know if i can add a remote start addon unit  like the valet 561t  to work with factory remote.and if i can how do i do it
thank you
profuse007
Gold - Posts: 2,015
Posted: May 23, 2004 at 9:20 PM / IP Logged
-yes you can!!
-wire the remote start add-on like any other stand alone unit but it has a wire that control by an external unit like ur factory alarm w/ 2 negative pulse.
-to find this wire, 561t should say remote start input, ithink its WHITE/ blue (-).
-to obtain 2 negative pulses, use the doorlock wire. you must diode isolate them just incase someone from inside the car can start up the car accidentally w/ the rocker switch.
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|lt grn (key sense)*5|- |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
| SECOND ACCESSORY|brown               |+ |ignition harness            |
|       POWER LOCK|lt. blue            |+ |drivers kick panel          |
|     POWER UNLOCK|white               |+ |drivers kick panel          |
| PARKING LIGHTS +|brown               |   |headlight switch            |
|     DOOR TRIGGER|*1                  |- |*1                          |
|TRNK/HTCH RELEASE|gray or black       |+ |behind fuse box             |
|       TACHOMETER|white or orange     |   |ignition module *2          |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|lt blue             |+ |brake pedal switch          |
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 Use gray/black for the drivers door and lt. GREEN/ black for the passenger door(s). The gray/black is located near the diagnostic plug harness under the drivers side of the dash, and the lt. GREEN/ black is located in a black 24 pin plug behind the fuse box in the center console. Use both wires and diode isolate each. *2 Ignition module is on the center front of the motor. Can also find tach at the PCM located behind the battery. *5 The lt. green key sense wire at the steering column must see a ground during remote start to keep the SERVICE light from coming on.
*****difficulty from 1-5, i would rate it at 4. it require diode, relay, and bypass
Houston,TX
crash1ny
Member - Posts: 7
Posted: May 24, 2004 at 8:11 PM / IP Logged
so how would this work if it is hook up to the locks would it start evey time you lock the doors
Platinum - Posts: 12,488
Posted: May 24, 2004 at 10:20 PM / IP Logged
No you will need to program the unit to remote start upon two or three pulses. If the unit only gets one pulse it will not engage.
