alarm going off
Raul Puente
Member - Posts: 23
Posted: May 26, 2004 at 4:13 PM / IP Logged
 i have installed a ultra start 430 on a 95 chevy s10. my problem is that it works  fine until you start the enginethen the alarm goes off and you cant disarm it or over ride it.i replace the unit with another one and the same thing.the wires i hook up are correct but also the car has aproblem with it's brake lights. what i'm thinking is .that abad current is going to the lights and messing it up. thanks
revmatt99
Member - Posts: 28
Posted: May 26, 2004 at 4:56 PM / IP Logged
Is it the factory alarm or an after market?
Raul Puente
Member - Posts: 23
Posted: May 26, 2004 at 6:39 PM / IP Logged
ultra start is a after market alarm
sparkie
Platinum - Posts: 2,061
Posted: May 26, 2004 at 9:43 PM / IP Logged
Unless your unit is an alarm/remote starter combo unit, it's supposed to go off if you start the car. Your shock sensor is either triggering the alarm or it is sensing the ignition turning on. The reason that the alarm won't disarm once it is started is that the ignition wire to the alarm is telling the alarm not to respond to the transmitter if it receives a arm/disarm signal. This feature is designed to prevent you accidentaly arming the alarm while driving. The only feature that will work is the panic option. If your alarm did shut off or didn't go off with starting, then a thief wouldn't have much trouble stealing it.
sparky
Raul Puente
Member - Posts: 23
Posted: May 27, 2004 at 9:06 AM / IP Logged
ok i unstand what your saying, but even when you trurn off the ing;
you still cant turn it off. i disconnect the 12volt  wire and then pluged it back in
and it still won't disarm/arm. and no it just abasic alarm.
Manoftools
Copper - Posts: 55
Posted: May 27, 2004 at 11:12 AM / IP Logged
Sounds like your disarm/unlock wire is not hooked up properly, so it will not disarm even when you disconnect power.  Also I agree that your shock sensor may be the culprit for turning the alarm on in the first place.  As far as the brake lights, I dont see any reason they would affect a standard alarm.
Raul Puente
Member - Posts: 23
Posted: May 27, 2004 at 5:00 PM / IP Logged
ok i read what was reply and let me make myself clear
this ALARM does not have a remote starter and also has no
power door lock they are manuel, the ? is sense the brake lights
are not working would it send a bad current back to the brain
to make it act that why,also i replaced it once with another brain
and the samething happened. the only wires that are hooked up
are 12volt -ing;-parking+lights-doortrigger and the siren wire and ground
Boys
Member - Posts: 14
Posted: May 28, 2004 at 10:44 AM / IP Logged
i will recomend to test ur wiring again whith dmm
if not it my be the impact sensor is not bypass... also make sure battery is not low
nava94
Silver - Posts: 296
Posted: May 29, 2004 at 10:44 PM / IP Logged
You should test your wires again with a dmm your 12volt wire you tapped into might be an acc. wire.
Raul Puente
Member - Posts: 23
Posted: June 01, 2004 at 12:52 PM / IP Logged
i found out what the problem was it was the car not the alarm or the install. the car had some bad connention before the install.
thanks everybody.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
