thor alarm, expedition
jpawloski
Member - Posts: 9
Posted: June 10, 2004 at 10:02 AM / IP Logged
Hi,
I just bought a thor alarm with the lcd, doesnt look to bad just for cheapy, but anyways.
Where and what wires do i connect into for door locks.
My 99 expedition has got keyless entry.
thx again
jfk51502003
Copper - Posts: 221
Posted: June 10, 2004 at 10:26 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / EXPEDITION / 1999 / Remote Start
[PRINT THIS PAGE]
12voltsyellow, grn/purple + ignition harness
StarterRED / lt. blue + ignition harness
Second Starter
Ignitionblue/lt. green + ignition harness
Second Ignitiongray / YELLOW(2nd acc) + ignition harness
Third Ignition
AccessoryRED / black + ignition harness
Second AccessoryBLACK/ green + ignition harness
Keysense
Power Lockpink / YELLOW - keyless module
Notes: The keyless module is located high in the drivers kick against the firewall.
Power Unlockpink/green - keyless module
Lock Motorpink/black drivers kick panel
Unlock MotorRED / orange drivers kick panel
Parking Lights+brown at light switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggerlt. blue/white - keyless module
One of two. The wire is in pin 11 and it is next to the BLACK/ pink wire. Test with a digital multi-meter ONLY, to keep from damaging the circuit tied into the other lt. blue/white.
Dome SupervisionBLACK/ lt. blue + passenger kick panel
Trunk/Hatch Pintied in with door
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm ArmN/A
Factory Alarm DisarmN/A
Disarm No UnlockN/A
Tachometer
Notes: Tach wire: On the 4.6L it is a pink/white in a 3 pin plug at the front of the motor below the air intake and next to the fan. On the 5.4L it is a lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors.
Wait to start
Brake Wiregreen + at brake switch
Parking Brake
Horn Triggerdk. blue - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module:Required: YesType: PATSPart #: 555P, 555F, or 555U
Notes: N/A
thor alarm, expedition -- posted image.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
