Alpine 8048
jwillcox
Posted: June 10, 2004 at 7:46 PM / IP Logged
Hi guys n gals.  I have had my 8048 for a long time it's installed in my 1999 Chrysler Cirrus the range on the remotes suck and i would like remote start so i  bought a Vizion CM4200 car starter with awesome range and would like to hook it up to the 8048. I found the post of wiring info for the 8048  by Velocity Motors and the factory arm/disarm wires are not listed on the info. Does anyone know the wires i seek?  Are the wires inputs so that i can hook up the remote starter?
draasch
Gold - Posts: 2,172
Posted: June 11, 2004 at 6:02 AM / IP Logged
this is the car info:
OEM Alarm Arm SINGEL WIRE SYSTEM 12 PIN CONN. IN DRIVER DOOR *
OEM Alarm Disarm L GREEN/ ORANGE BOOT OR DRIVER KICK PANEL
* L GREEN/ ORANGE Single Wire Will Arm And Disarm. Must See 12VDC (+) Thru A 873 Ohm Resistor To Arm And 12VDC (+) Thru A 270 Ohm Resistor For Disarm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jwillcox
Posted: June 12, 2004 at 6:02 PM / IP Logged
Hehe thanks for a reply draasch, but that is not what i'm looking for. The alarm in the Cirrus is a Alpine 8048 not an OEM. Would you happen to have the Alpine 8048 wiring?
draasch
Gold - Posts: 2,172
Posted: June 12, 2004 at 6:15 PM / IP Logged
"I found the post of wiring info for the 8048 by Velocity Motors and the factory arm/disarm wires are not listed on the info. Does anyone know the wires i seek?"
is the alpine just an alarm system??? or does it have a remote start as well???
Good Luck
David
Ace Security
813-376-9778
Tampa
