2004 Ford F350 alarm/remote start
superfly
Member - Posts: 10
Posted: June 11, 2004 at 8:44 PM / IP Logged
Hi guys, does anyone have a wiring diagram for a 2004 Ford F350 Superduty for installing an alarm/remote start?  Also does anyone know which bypass module I would need?  Dei 555f or 555U?  If anyone has any info I would greatly appreciate it.   Thanks guys.
Check twice, install once. Superfly
tsu708
Member - Posts: 6
Posted: June 12, 2004 at 12:17 PM / IP Logged
Hope this helps,
I have a 2004 F-250 Superduty, I don't need the bypass module beacause there is no chip in the system, you can start the truck with a $1 copy of the key.
Also, you may need a pulse timer relay if it is diesel
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1091.pdf
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2004 / Remote Start
[PRINT THIS PAGE]
12volts yellow & lt. GREEN/ purple  +  ignition harness
Starter green  +  ignition harness
Second Starter N/A
Ignition RED / lt. green or WHITE/ yellow  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW & RED / black  +  ignition harness
Second Accessory blue/lt. green  +  ignition harness
Keysense
Power Lock see notes
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlock see power lock notes
Lock Motor pink/black  5wi VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor RED / orange  5wi VSM
Parking Lights+ brown  +  headlight switch
Parking Lights- N/A
Hazards same as turn signals
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +  steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +  steering column
Reverse Light BLACK/ pink  +  fuse box
Door Trigger BLACK/ lt. blue  +  passenger kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer NOT RED / lt. green  ac  any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green  +  brake pedal switch
Parking Brake lt. GREEN/ red  -  parking brake switch
Horn Trigger blue  -  steering column or VSM
Memory Seat 1 BROWN / lt. green  -  memory mod under dr seat
Memory Seat 2 BLACK/ orange  -  memory mod under dr seat
Memory Seat 3 N/A  -
2004 Ford F350 alarm/remote start -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
tsu708
Member - Posts: 6
Posted: June 12, 2004 at 12:28 PM / IP Logged
Hope this is what you need.
I have a 2004 F-250 Superduty, I do not need a bypass cause there is no chip in the key. You can start vehicle with a plain $1 copy of the key. So there is no bypass.
Also if your truck is diesel, you will probaly need a pulse timer relay. Instead of using wait to start light.
Pulse timer relay diagram link:
[PRINT THIS PAGE]
12voltsyellow & lt. GREEN/ purple + ignition harness
Startergreen + ignition harness
Second StarterN/A
IgnitionRED / lt. green or WHITE/ yellow + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorygray / YELLOW & RED / black + ignition harness
Second Accessoryblue/lt. green + ignition harness
Keysense
Power Locksee notes
Power Unlocksee power lock notes
Lock Motorpink/black 5wiVSM
Unlock MotorRED / orange 5wiVSM
Parking Lights+brown + headlight switch
Parking Lights-N/A
Hazardssame as turn signals
Turn Signal(L)lt grn/wht (F), lt grn/org (R) + steering column
Turn Signal(R)wht/lt blu (F), org/lt blu (R) + steering column
Reverse LightBLACK/ pink + fuse box
Door TriggerBLACK/ lt. blue + passenger kick panel
Dome Supervisionuse door trigger
Trunk/Hatch PinN/A
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Arm
Disarm No Unlock
TachometerNOT RED / lt. green ac any ignition coil
Wait to startsee DirectFax document 1091
Brake Wirelt. green + brake pedal switch
Parking Brakelt. GREEN/ red - parking brake switch
Horn Triggerblue - steering column or VSM
Memory Seat 1BROWN / lt. green - memory mod under dr seat
Memory Seat 2BLACK/ orange - memory mod under dr seat
Memory Seat 3N/A -
Notes: N/A
brianh
Silver - Posts: 518
Posted: June 12, 2004 at 1:53 PM / IP Logged
There is no usable tach connection on the 03, and 04 trucks. These trucks will not work in tachless mode either. I had to use a unit that had starter timer mode in order to get the R.S unit working. I set the time to 1.2 seconds and it worked like a charm. I have done several of these trucks like this and have not had them come back. Good luck with the install.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
superfly
Member - Posts: 10
Posted: June 12, 2004 at 4:53 PM / IP Logged
Ok thanks guys, time for doing a little metering now.  I do believe I do need a bypass though, this particular truck is a Lariet edition and it has an ignition immobilizer by the way it looks, there is a bulb on the dash.  Thanks again for the info guys, I appreciate it.
Chris
extreme1
Silver - Posts: 1,070
Posted: June 13, 2004 at 2:51 PM / IP Logged
tach is GREEN / WHITE taped in harness left of brake pedal, there are 5 wires there.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
superfly
Member - Posts: 10
Posted: June 21, 2004 at 6:09 PM / IP Logged
Thanks for all of the help guys, the install was perfect.  Tach wire was GREEN / WHITE behind the fuse block taped to the harness.
dwelch1
Posted: June 23, 2004 at 5:13 PM / IP Logged
I am getting ready to install a Keyless entry/ Remote start on my 2004 F-250, I bought a Crimestopper CS-2011RS (waiting on delivery) any tips ect?
Donnie Welch
dwelch1@insightbb.com
Tuesday, January 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
