clifford cliffnet pro wizard
recombinator
Posted: June 19, 2004 at 7:27 AM / IP Logged
Hi all,
i recently bought an avantguard g5 system and installed it in my car. Now i ordered a wizard kit but i'm looking for the PRO version software so i can adjust the prox. and everything on the system. Could someone send me a copy of this please???
i now there's al lot of old topics about this, but none leed to the software really.
Thx a lot .
R.
recombinator
Posted: June 20, 2004 at 6:59 AM / IP Logged
is there no=one who could send me this??.......i looked at the old links in the old topics but they point to the user-version of the software........
datrick
Member - Posts: 33
Posted: June 20, 2004 at 10:18 AM / IP Logged
Hi,  you cannot adjust the sensors with cliffnet pro.   Sensor must be adjusted by using the transmitters.    By the way, that is a nice system you got there.   Did you do the install yourself?
datrick
Member - Posts: 33
Posted: June 20, 2004 at 10:41 AM / IP Logged
I was beginning this year in Europe including Holland for vacation.   Went to a clifford store, and DAMNNNNN are the prices for a system way too expensive.    I have been told about 1200 euro for Avantguard G4 excluding install????   Also been told that the G5 was not avalaiable and maybe december 2004?
Cliffnet Pro and Cliffnet User are basically almost the same.     In the Pro version installer have acces to installers menu.
recombinator
Posted: June 20, 2004 at 5:07 PM / IP Logged
Yeah did the install myself.....but i was told that i could adjust more with the PRO software version. Withe user version ther'es almost nothing to do.
The alarm isn't officialy available here yet and prices are indeed way to high. But a friend of mine bought one in america and took it for me. So that way it costed about 700 dollars.
Steve #1
Member - Posts: 35
Posted: June 21, 2004 at 2:14 AM / IP Logged
recombinator, check your PMs.
recombinator
Posted: June 22, 2004 at 1:23 AM / IP Logged
Well.........i've got the G4 PRO Version now..........anybody wanna trade for the G5 PRO version?? :).....still looking for it.
dei user
Member - Posts: 44
Posted: June 22, 2004 at 6:06 PM / IP Logged
hey buddy  i am aclifford g5 specialist here in miami fl  usa. in order to adjust and program your proximity sensor u have have all your windows up on the vehicle close all doors and have the alarm disactivated. press clifford on your remote control transmitter 3times and then press the button that has 1 star.it will give u one chirp and your led light will come on.you r already in primary zone for the proximity sensor.now to adjust sensitivity to iincrease u press the trunk button on your remote transmitter and to decreaseu press the button that has one star.if u increase the chirps will be higher and if u decrease the chirps will be lower.u will lower the sensitivity all the way down until u get 2 chirps that means u have gone to minimum sensitivity.once that is down press the button that has 2 stars . now you are in warn away zone u adjust the sensitivity the same way u adjusted it in the primary zone. remember trunk button to increase and the one star button on the remote.in the warn away zone u will go ahead and increase the sensitivty.every time u increase stop momentarily and approach the divers window as into u wanted to look inside like a thief would. if alarm does not give u one chirp when u approach window continue increasing the sensitivity and approaching the window until it gives u one chirp. when one chirp is given stop increasing and approach the car and walk away.if the alarm chirps every time you approach taht means u have gooten a reasonable sensitivity.if it only does it once or twice from many times testing continue increasing once or twice and then test again for constant chirping when you approach the car.when goten to desirable sensitivity  that u are satisfiedd with press the lock button u should receive two chirps u are back on primary but do not adjust  it simply press the lock button once again and it will give uthree chirps. u  have fully exited programing on the proximity now open door and then close again and activate the alarm. allowe about one minute and a half for the sensors to fully adjust. then approach the window and it should chirp strangley. leave alarm activated and test all four window doors and it should chirp strangely  every time .if found to high or to low the sensitivity simply press the button that says clifford once again and then the button that has one star once u will go back to primary zone on the proximity skip the primary by pressing the button with the two stars. u will then be once again in the warnaway.u can now go higher or lower as explained before.once that press the lock button once and it should give u two chirps.press the lock button again to fully exit  and retest as explained before. if u are satisfied disactivate alarm and go back to program proximity by pressing the cliffford button 3 times and then the button with one star once.but before u begin entereing the programing make sure to go and roll down your windows  on your car. and then enter programming.remember then once you have pressed clifford buttton 3 times and then once the button with one star u are entering the primary zone  once there go ahead and start increasing the sensitivity by pressing the trunk button once again  continue increasing as the chirps go higher and higher. as u do that also start sticking your hand into the vehicle like if u wanted to grab the radio.if it chirps stop and press the lock button it should give u two chirps press it once more and it will give u three chirps u have fully exited the programming sequence. activate the alarm again but remember to always give the alarm about one minute and a half so the sensors can fully adjust. then stick your hand in the vehicle and act like if you wanted to reach for the radio. if it goes off you have completed programming the proximity sensor if not repeat the steps to adjust the primary zone.and test again  good luck in that if u have any other questions do not hesitate to ask. u have a amazing security system does it reote start well ? doest it ask u for the code and the tilt sensor does it work and the omnisensor also ?
   P.S.    you can also get something called smart windows it allows u to make your windows go up if u left them down when activiate your alarm.but of course you have to have power windows.another cool thing is  u get to have ontouch up and on your window switch for all windows. but every one module that u get  controls only two windows so u have to get two modules if you have a four door.
dei user
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
