'87 mercedes alarm help
samgeez
Posted: June 23, 2004 at 8:49 PM / IP Logged
I am in desperate need of help.  I have installed the crime guard alarm system w/ remote start to my '87 190e 2.6.  The car has a factory alarm that would go off while i was driving when I used the remote unlook option and not the key.  I was able to locate the GREEN/ YELLOW (i believe the disarm) wire coming directly from the factory alarm box, which is where I then connected to the disarm wire (negative pulse) coming from my new alarm...
Problem....when i try remote start after disarming, the factory alarm and new alarm goes off.  So I unhooked the factory alarm plugs (two of them) and now my new alarm still goes off and cuts of the starter when i try to remote start.
Questions...what is the correct way to disable the factory alarm and any idea what is keeping my remote starting from working?
Please help!
thanks
87 190e 2.6
Javelin3o4
Copper - Posts: 239
Posted: June 24, 2004 at 1:26 AM / IP Logged
http://directechs.com/directwire/wire_body.asp?action=select&yr=736&product=Remote%20Start
1 A purple starter wire is available in the drivers kick panel. This wire SHOULD NOT be used with remote start installs, as it is on the wrong side of the neutral safety switch.  *2 The diagnostic connector is covered by a black round cap and is located between the LF headlight and the shock tower.  *3 BROWN / gray for front and gray/black for rear. The rear doors can also be found at the dash mounted rear dome light switch (gray -).  *4 The anti-theft unit is located in the passenger footwell under a plastic cover against the firewall.
draasch
Gold - Posts: 2,172
Posted: June 24, 2004 at 1:40 AM / IP Logged
double check all wires with this info.....
Make:   Mercedes Benz
Model: 190D & 190E
Year:    1984-92
Alarm
Constant 12 volts RED AND RED IGNITION SWITCH HARNESS
Ignition 12 volts RED / BLACK IGNITION SWITCH HARNESS
Starter VIOLET/WHITE IGNITION SWITCH HARNESS
Dome Light BROWN / GRAY AND GRAY SEE NOTES BELOW *
Trunk Pin Switch NO COLOR AVAILABLE
Parking Lamp GRAY/WHITE (DR) & GRAY (PS) (+) AT HEADLIGHT SWITCH***
Power Lock GREEN, BLUE OR YELLOW ALL THREE WIRES #210
Power Unlock VACUUM DOOR LOCKS PRESENT AT PUMP **
* Rear Pin Switch And BLUE Door Lock Wire Can Be Found Below Driver Step Plate In Protective Tubing. #210- See Mercedes Door Lock Diagram. ** This Car Uses A Vacuum System For Power Door Locks. Correct Door Lock Wire Will Switch Between Ground And 12V (+) Constant When Locking And Unlocking Doors. *** See Tech Notes!!
Remote Start
Tach Signal GREEN/ YELLOW AT IGNITION CONTROL MODULE
Ignition #2 RED / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory RED / GREEN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - O.E.M. SWITCH OPENS STARTER CIRCUIT
Brake Light BLACK/ RED (+) AT BRAKE SWITCH
Reverse Light GRAY / YELLOW (+) GEAR SELECT SWITCH
Rear Window Defrost N/A
** Split Parking Light System- Use Two S.P.D.T. Relays Or Two 6 Amp Diodes To Isolate.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
draasch
Gold - Posts: 2,172
Posted: June 24, 2004 at 1:43 AM / IP Logged
OEM Alarm Arm YELLOW/BLUE (-) DRIVER KICK PANEL
OEM Alarm Disarm GREEN/ YELLOW (-) DRIVER KICK PANEL
Good Luck
David
Ace Security
813-376-9778
Tampa
samgeez
Posted: June 24, 2004 at 11:10 AM / IP Logged
thanks for the help! I will try it out today
87 190e 2.6
MBZ oe
Silver - Posts: 385
Posted: June 24, 2004 at 11:39 AM / IP Logged
You do not need to connect anything to the factory disarm if you have connected the lock/unlock wire correctly. Because it is the same thing as using the key, it already disarms your factory alarm. I just went through these issues installing a clifford matrix 3.5 remote start security system in my 87 300E. Use the wiring diagram on this website for your car and it will tell you where the wires are located as well as their colors.
Good Luck!
boom, boom, boom boom....
MBZ oe
Silver - Posts: 385
Posted: June 24, 2004 at 11:42 AM / IP Logged
Your door unlock/lock pulse needs to be changed to the 3.5 second setting versus default setting of .8 sec. If not, it nay not disarm your alarm since it won't unlock the door.
Saturday, January 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
