How many sensors?
skyace4
Member - Posts: 18
Posted: June 25, 2004 at 10:42 PM / IP Logged
I put a remote start and alarm system in a Chevy Pickup truck (2004).
The kit came with a shock sensor so it was installed and I also put a microwave sensor in the truck as well.
the 2 sensors are each dual zone types, now I have a single zone motion sensor I was thinking of installing, would it be worth a motion sensor and a shock sensor on the same system?
Could I wire a single zone sensor into a dual zone sensor system?
auex
Platinum - Posts: 5,041
Posted: June 26, 2004 at 12:34 AM / IP Logged
Read your install manual. You can add 10^9999 sensors to the alarm if you wanted to (get the point). Also motion and shock are two completely different things and should not be compared. For example, I can jack your car up with a shock sensor and the alarm would never go off or I could hit your car with a baseball bat with a motion detector and the alarm would never go off.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
