PATS with one key
wickedties82
Posted: July 08, 2004 at 8:23 PM / IP Logged
I want to put remote start on my 03 focus.  I understand that the 555s needs to keys to work.  I lost my #2 key is there any other way to bypass or permantly dissadle pats
wickedties82
Posted: July 08, 2004 at 9:24 PM / IP Logged
one more thing could i just get the 555U put my pats key in that and use a cheap copy key from home depo to start the car?
Javelin3o4
Copper - Posts: 239
Posted: July 08, 2004 at 9:42 PM / IP Logged
I belive you would need to go to the dealership and have the get you a 2nd key.
djrock
Member - Posts: 24
Posted: July 09, 2004 at 5:46 PM / IP Logged
If its the same system i am thinking of i was told buy a local company how they disable these systems after the owner has broken there master key and does not have a spare key with the chip, is they take off the cover that covers the ignition. There should be a ring of plastic with a wire coming from it around the ignition lock. What they do is take say the broken master key and cable tie it to the ring so a standard key starts the car.
djrock
