790xv remote can receive, but not send
Kongo
Member - Posts: 12
Posted: July 26, 2004 at 12:55 PM / IP Logged
Hello!  Okay, here's my first thread.  I registered to get some help.... thanks in advance.
So I have the Viper 790xv installed in my 1997 Accord.  I know about all the problems from a friend, including the remote problems, the remote start issues... etc.
Anyways, my alarm was working fine all yesterday, and then all of the sudden, I can't arm or disarm my alarm with my remote.  I tried reinserting the battery, no luck.  When I push the arm or disarm button, it makes the 3 beeps signaling that the transmission wasn't sent (or out-of-range).
So I have to manually disarm using the valet switch, by using my key to get in (setting off the alarm).  When the alarm goes off, my remote beeps and lets me know that someone opened my door.
So, my remote is receiving transmissions from the car, but I can't send (that's what it appears, anyways).
What do you guys think?  Thanks!
nguyenk
Member - Posts: 31
Posted: July 26, 2004 at 1:39 PM / IP Logged
Those remotes are notorious known for failing.  Let's hope it's under warranty.  Did you try using the other remote (the one-way one) to see if it is working?
Kongo
Member - Posts: 12
Posted: July 26, 2004 at 1:41 PM / IP Logged
What "one-way one"?  I only got the one transponder remote.   Maybe I'll try disconnecting/reconnecting the antennae?   Does this work sometimes?
nguyenk
Member - Posts: 31
Posted: July 26, 2004 at 2:06 PM / IP Logged
I thougth the 790 comes with two remotes, the two way remote and a one-way remote.  You can use the one way remote to do everything on the alarm except for things that come back from the brain.  I read somewhere that re-connect the antennae does help so try that....
nguyenk
Member - Posts: 31
Posted: July 26, 2004 at 2:08 PM / IP Logged
I was wrong.  The viper 790VX comes only with the two-way remote.  I was thinking of the Hornet 554T.  Sorry
sroth140
Silver - Posts: 513
Posted: July 26, 2004 at 2:36 PM / IP Logged
something simple to try is unplugging the antenna from both ends, and plugging it back in.  this has worked on several cars for me.  any other problems non-remote related are going to be due to the installer.
MECP certified installer
Kongo
Member - Posts: 12
Posted: July 26, 2004 at 7:21 PM / IP Logged
can anyone else chime in?
